LED emmiters and moisture
When I bought LED emmiters from Farnell or Mouser I recieved them in a sealed antistatic bag with a desicant.
Just now I recieved Luxeon V2 from mouser and the package had this ticker on:
I tohught the shelf life of LEDs was nothing to be concerned about but now I’m not so sure. The spec sheet for Luxeon V2 says that JEDEC moisture sensitivity is level 1 and it doesn’t even talk about shelf life, but the sticker says different.
How catious are you with your emmiters?
I think they mean the contact surfaces. In order to get the best conductivity of both heat and electric current, you want a clean bond. So, the contact surfaces need to be kept clean and dry. But I don’t really know if that’s it. I’m mostly speculating. :smiley:
arrow has the same text/print. they even send a humidity tester with the shipment, they are always pink though? Isn’t that bad? either way, they all worked for me.
I’ve looked into some more spec sheets
I paln to use Samsung leds for my next project and it looks like I’ll have to bake them. The question now is how to bake? Would a table top kitchen oven do?
I would think there are two necessary attributes for an oven to bake the LEDs properly:
  1. The oven has to be able to maintain the correct temperature setting fairly consistently.
  2. The LEDs should be shielded somehow from the direct radiation from the elements, because the radiant heat might make them too hot.
