Sky Lumen Nguyen Flashlight
Unfortunately it is too high :frowning:
I cant get around that unless have it made in China.
:wink:
View post on imgur.com
at least Vinh is honest :wink:
Finally we can get a true 10k+ lumen single cell flashlight!
I would be VERY surprised if it could stand up to 9mm. LockPickingLawyer and BosnianBill recently shot a bunch of locks and InRangeTV has been doing AR500 armor penetration testing.
SLN Test 8: Subzero
SLN Test 9: Boiling Point
SLN Test 10: @ Depth
Your excitement is contagious! Congratulations on passing the deep water penetration test! :+1:
That was my fav test video to date. Gave me a tear or two from watching you as happy as you were.
Congrats Vinh!
and that’s not even a diving version! The drop test is my most anticipated video. Can’t wait.
Thank you for all the support! I dearly appreciate it. First step to everything is usually the hardest.
The drop test is schedule for tomorrow. We will do the drop test with the unpotted light engine that we have been using for all the tests so far. If it pass then wonderful. If the light engine fails then I will make another light engine that is potted and redo. Potting will be optional at time of order. I suspect most will not need this option as it adds little benefits if our current light engine passes all the drop tests.
Today after the “@ Deapth” test I found out the optics seems to be a bit bent from heat. I am sure the “Boiling Point” test did this because I did not notice this before that test. Beam is still good and light of course operated flawlessly but I thought I mention that. If you are going to cook the light without a battery inside then the optics is the weakest link.
Test 1: Bucket Water Dunk
Test 2: High Water Pressure
Test 3: Corvette Drive Over
Test 4: F150 Drive Over
Test 5: Heat Test
Test 6: Chemical Resistance
Test 7: Heat Test 2 - 4000L High Drain Samsung 30T
Test 8: Subzero
Test 10: @ Depth
Test 11: Impacts
Test 12: Drag It
Can guarantee you this light will be $300+
If we buy it from you? :slight_smile:
This is basically a custom Made-in-the-USA light in very limited quantities. Given the manufacturing cost here and the amount of time and effort spent developing and testing this light, even at $300, I don’t see how it is profitable, but it is a good start and is probably the 1st USA made light geared toward flashlight enthusiasts so I will definitely buy one to give my support. Hopefully the 12-emitter version won’t be too much more expensive than the others. :wink: I will probably supply my own emitters
Would be interesting to submit say a convoy S2 or an other reasonably priced tube light to the same test at the same time to have a baseline and validate the design choices.
I remember some years back at CPF people were suspecting a particular light with very thin walls would be fragile, someone torture tested it in like manner and it passed with flying colors.
Not much I can do about the host price. I am lucky Larry help with the drawings all for FREE. Otherwise I wouldn’t make a single dime on it if not acatully lose money. The light engine is where I am hoping to make the profit. However I will make them as affordable as I possible can especially the 12 LEDs one since that is one I want as many people to have. Just looking at it would be a joy. The good news is you only have to purchase the host once. It should last a lifetime and upgrades down the road wont be too pricey. Future lego parts are also in the planning to make the light suitable for even more audiences. Also if the light is made from 2011 we might be able to drop the price may be $50. If we go 6061 may be a bit more…But I suspect once we have 7075 in hand it might be worth it just to go all out with this metal. I cant wait to get my hands on it.
I ran over a light which I wont name and it didnt hold up the first run over asphalt with the truck. I decided not make a video on it as putting down another brand isn’t my intention. I am not trying to display what other brand lights cant do. I simply want to shows what mines can. Other brand lights will do many many things mine can’t. They night not pass all my 12 tests so far but they might pass other tests that are more crucial to the decision such as looks and functions that mine will not provide. As a light enthusiast, I honestly treasure and enjoy them all (except for *Fire clones). No point is putting down another to validate my design choices.
The toughest test was likely the “@ depth” and the “Drag It”. I suspect most of my other lights will not pass those tests. Yet, I know mines will not pass the tests that those lights will have for mine…
I see.
For reference i found the thread mentioned here , pretty impressive for a thin walled multi battery light.
Seems the Fenix store themselves used these as marketing technique.
Are you saying that the light engines can be swapped like P60?
Yes. The user can swap light engines anytime they want. Future upgrades to the light engine or to replace with a new one is a breeze.
