Test/review of Blackube AA 2550mWh USB (Gray)
Official specifications:
  • Voltage: 1.5V
  • Energy: 2550mWh
  • Output current: 4000mA
  • Charging current: 5V/350mA
  • Charging time: about 2h
  • Cell type: Li-polymer
  • Life time: 1000-3000 cycles
  • Weight: 19g
This is a USB charged 1.5V battery, there is a LiIon cell, a buck converter and a charge circuit inside.
Behind the hole is a red led, it shows red while charging and turn off when finished.
Included with the batteries is a 4 way USB charging cable, i.e. any 2A USB charger can charge four batteries simultaneous.
The capacity depends a bit on the load current, but output voltage is stable.
At low current the capacity is also lower, because the internal regulation also needs some current. This cannot really be seen from my curves here, i.e. the internal current consumption is very low and the battery will last for many months before it has discharged itself.
The battery can deliver up to about 4A before the overload protection kicks in.
The electronic circuit makes the internal impedance look strange.
Output voltage do not change much when load is turned on or off.
It looks like the buck regulator runs at about 1.2MHz. The noise is less than 30mVpp, but I cannot measure lower with the current setup.
Conclusion
These batteries has less capacity than normal NiMH, but run at a higher voltage, making the energy about the same. This makes them ideal for most equipment that has trouble with NiMH batteries. They also weight considerable less than NiMH, this can be significant in some circumstances. There is one disadvantage: Battery meters do not work with them.
The USB charging makes it very easy to find a charger for them.
Notes and links
The batteries was supplied by Blackupe/roca-sup.com for review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
This cell looks good, at least its current limit is much higher than the other 1.5V li-ion + buck solutions. Can it handle, say, 2.5A~3A continuous discharge?
Thanks HKJ! Another interesting cell that it is nice to to be aware of.
I have added a 3A discharge curve.
Thanks HKJ, really appreciate that :+1:
Those look interesting. I like where the USB port is.
To be honest, I’d be tempted to try them just for the 4 port charge cable.
I’m guessing that putting them in a standard charger is completely verboten?
Of course it is, but I doubt anything will happen if you do.
The internal switcher converts 3-4V down to 1.5V, feeding 2V into the 1.5V output will most likely be harmless. If the open circuit voltage of the NiMH charger is 4V or more, it may damage the battery.
It never pays to underestimate your average idiot, and their ability to make life…. interesting. :person_facepalming:
For extended reading on this see the comments in [Slickdeals] or Amazon.
Anyone know where to get these?
(Amazon does not seem to ship them to Australia)
