I really like the concept of JETBeam FL-12 but 42$ for 780lm of probably very floody light still lets me hesitate.
Fin17
(Fin17)
1036
Lexel
(Lexel)
1037
MF01S 6500K or 5000K CRI is wrong only 4000K are 95 CRI SST-20
Fin17
(Fin17)
1039
Coupon limit increased to 5 times for each customer.
TexasToasted
(TexasToasted)
1041
I like that red splatter paint look on the Xanes 3320. Ordered one for Halloween
Nicolicous
(Nicolicous)
1042
red splater looks photoshoped.
doubt you get what it looks in the image
RapidLux
(RapidLux)
1047
Do you have code for Xiaomi Nextool Flagship Pro 16-IN-1 Pocket Multitool?
Thank you!
dnei519blf
(dnei519blf)
1048
Hi Fin17,
Is there any coupon for Convoy S2 UV flashlight with LG 365 nm LED and 7135*5 driver?
Thank you so much!!
d_t_a
(d_t_a)
1049
Does this mean the X8R-C (bigger head) head portion can be bought stand-alone?
Another question (in case some may know insider info…)
“Eagle Eye” brand seems to be relatively recognizable (EE X2R I think is a good flashlight, very similar to the popular Convoy S2+).
I remember seeing that the name got changed to Rixingguang (direct translation from Chinese is “Sun-Stars-Light” as per some sources).
And then now, it got re-branded to “Mezzol” — I wonder if that name means something?
Fin17
(Fin17)
1050
I saw a separate head on Aliexpress:
http://bit.ly/2miduvL
Sorry i’m new to banggood but can you only use 1 coupon code per order?
neBstress
(neBstress)
1052
Hi eyespeakbraille,
Yes, only 1 coupon per order.
Fin17
(Fin17)
1054
BlitzWolf® BW-P9 10000mAh Power Bank
with Fast Charging, Dual Input and Output
for iPhone, Samsung, Xiaomi, Huawei
$13.99 - with my exclusive coupon code BGfin1701
Feature:
PD 3.0 Protocol
The latest universal charging protocol, charge faster and smarter than ever before.
18W Max Dual Output(Type-C + SUB ) and Input(Type-C + Micro)
Compatible with PD3.0,PD2.0, QC3.0 & QC2.0,It only takes 4h to complete 10000mAh at 12V/15A(Max).
Reliable Multi-layer Protection
Reassuring Over-charging Protection, Over-charging Recovery Voltage, Over-discharging Protection, Over-discharging Recovery Voltage, Over-current of Discharging, Over-current of Charging, Short-circuit, and Temperature Protection.
Specification:
Brand |
BlitzWolf® |
Model |
BW-P9 |
Color |
Black |
Capacity |
10000mAh |
Battery Type |
Lithium Polymer Battery |
Ports |
USB A + Type C + Micro USB Ports |
Power |
18W Total |
Input |
TYPE C/Micro USB Input:5V=2A,9V=2A,12V=1.5A |
Output |
TYPE C Output: 5V=3A,9V=2A,12V=1.5A
USB A Output: 5V=3A,9V=2A,12V=1.5A |
Fast Charging |
Type-C Input: Compatible with PD3.0 PD2.0
Type-C Output: Compatible with QC3.0 QC2.0 PD3.0 PD2.0
USB-A Output: Compatible with QC3.0 QC2.0
Size |
139*70*15.5mm |
Net Weight |
200g |
Weight |
230g |
Certifications |
CE, FCC, RoHS |
