Ordered a sand with the SST-40. Thanks!
I’m sorry, but I already ordered myself from a Russian contractor, they’ve already delivered it. I take pleasure. SST-40 for $ 20.
Just placed an order for 2 MARCH SST40, CW, Black & Sand
Thank you!
STT40 revised to $25, so that buyers get free shipping for their light. For those who paid shipping earlier, you will get a refund for shipping fee from Neal soon.
Hello FEEME,
ordered March C8 XHP 35 HI 6500K sand.
Thanks a lot!
Regards
Daniel
Thanks pal!
Hello, what bezel does it come with? Is it steel or aluminium? At ali they supposedly have both versions.
I also heard that rewrapped 21700 cells dont fit, is that true?
Mine comes with S/S (@17.4g). Please note that there is a faint magnetic attraction for their stainless steel grade.
One more question Freeme. Does the boost driver in the XHP35 version allow to use turbo with almost depleted battery? Is there any additional info on both drivers?
Yes, please use only 21700 with OEM wrapper. Keep within 21.1mm if possible. LISHEN 21700 blue cannot fit.
Unfortunately, i did not order XHP35 version. Cannot answer your question. There should be stepdown feature in firmware.
Manufacturer specified SST40 version is temperature controlled:
Stepdown from 7A to 4A when temperature reaches @±60°C. Once temp drops under @±50°C, output will increase to 7A. (To be verified).
Nealsgadgets has confirmed that all their stocks are with S/S bezel.
Will version XHP50.2(3V) be available?
XHP50.2 figures doesn't seems to be right. I asked Neal not to stock up first.
It is known what distance MARCH C8 XHP35 HI throws?
MARCH XHP50.2 - Turbo Activated.
Full Runtime graph to be presented at a later date.
Stepdown to 67.3% after C8 reaches 50°C (53°C exterior). Output increased to 80% after C8 is forced to cool down to 40°C (±42°C exterior).
Fluctuation between 37-73s period was caused by my IR thermometer measurement. Please ignore.
Test was aborted at 139s as value is almost constant.
I’m holding back til the xhp50.2 releases.
XHP50.2 figures doesn’t seems to be right. I asked Neal not to stock up first.
Unloco:Will version XHP50.2(3V) be available?
+1
All replied.
