Your result is way cooler than Maukka’s test. For bare LED without optic the CCT should be very close 5000-5500K and stays close to the BBL. SKV89 also tested almost all of my E21A and agreed to Maukka’s result (He also use the same Sekonic as yours). Please check your calibration.
Your duv number seems very negative. In real world such number will result in extremely magenta tint (which is not the case)
I ran a dark calibration just now and re-tested. The results are identical.
For reference, the 5pm sun a few days ago read 4919K and just now (8am) it reads 4670K. And yes, the appearance of the E21s is way WAY cooler than the daylight right now. I don’t doubt the meter.
I always thought Maukka’s CCT numbers were a bit low compared to reality. For example his test of the 219B SW45K leds showed them to be around 4200k, but they look more like 4700k.
Actually, from the diagram negative duv at such a high CCT is more blue that magenta as seen in in the CIE diagram. This perfectly explains the observation I posted here back in July about these E21s making plants look blue, not green at all.
Quote from July:
Suddenly everything is making more sense now that I have the data to back up my observations.
Your test of what I assume is a bare LED vs his test of integrated light is not comparable. You should throw a XML sized frosted or beaded TIR optic on top and see what you get
This is weird. I’ve tested many E21A (photo comparisons etc…) and have been using them until today, none deviates that much from those in the data sheet. And many people also satisfied with them. To my eyes, 5000K and 5700K are two CCTs most resemble daylight. Only 6500K appears “too blue”. I said this not because I sell these LEDs, but E21A is very popular for reasons.
In my opinion, your profile picture looks way too cool if they’re 5000K E21A. Too warm WB perhaps? You can check my beam and tint shots for comparison.
I’ve used probably 7-8 different reels of sw45k and they’ve measured anywhere from 4200K-4700K in a reflector, so I wouldn’t read into that too much. Plus bare LEDs, integrated LEDs, optics, and reflectors will all produce different results.
I trust what you are saying Clemence. But something is definitely up. Could there have been a mixup with some higher CCT ones in the same drawer when they were built, or just a different bin/batch?
BTW, both my quads perform same.
As for the profile pic, I believe the camera was set to 5000K as it should have been, but I can’t be sure anymore.
