freeme
(youtube.com/@1thedeals)
September 14, 2019, 2:10pm
82
Unfortunately, i did not order XHP35 version. Cannot answer your question. There should be stepdown feature in firmware.
Manufacturer specified SST40 version is temperature controlled:
Stepdown from 7A to 4A when temperature reaches @±60°C. Once temp drops under @±50°C, output will increase to 7A. (To be verified).
freeme
September 14, 2019, 2:14pm
83
Nealsgadgets has confirmed that all their stocks are with S/S bezel.
Unloco
(Unloco)
September 14, 2019, 2:34pm
84
Will version XHP50.2(3V) be available?
freeme
September 14, 2019, 2:53pm
85
XHP50.2 figures doesn't seems to be right. I asked Neal not to stock up first.
MARCH C8 XHP50.2 (CW) / 2246.9lm / 21700-48G / 6.45A
MARCH C8 SST40 (NW) / 1975.7lm / 21700-48G / 6.2A
ASTROLUX FT03 XHP50.2 / 4060.7lm / VTC5A / 9+A
Based on my initial test result. We have decided to proceed to stock up XP-L HI and SST40 first.
enesrap
(enesrap)
September 14, 2019, 3:32pm
86
It is known what distance MARCH C8 XHP35 HI throws?
freeme
September 15, 2019, 5:48am
87
MARCH XHP50.2 - Turbo Activated.
Full Runtime graph to be presented at a later date.
Stepdown to 67.3% after C8 reaches 50°C (53°C exterior). Output increased to 80% after C8 is forced to cool down to 40°C (±42°C exterior).
Fluctuation between 37-73s period was caused by my IR thermometer measurement. Please ignore.
Test was aborted at 139s as value is almost constant.
freeme:
blueb8llz
(blueb8llz)
September 14, 2019, 7:11pm
88
I’m holding back til the xhp50.2 releases.
Dioda
(Dioda)
September 17, 2019, 8:07pm
91
Hi what exactly is the SST40 color temp? Is it 5000k or the 5700 version?
freeme:
All replied.
Same again, did not receive the code(s). Can you please send me the information? Thank you.
mxyzptlk
(mxyzptlk)
September 19, 2019, 2:48pm
94
Hi,
just now I get my March C8 XHP 35 HI (21700) a very well manufactured Flashlight, with a clear, beautiful CW.
But there is a problem, the batterytube has a diameter of 21,6mm, which is very tight, so my Sofirn and LiitoKala batteries do not fit.
Does anyone have an idea which batteries could fit?
freeme
September 19, 2019, 3:00pm
95
Unprotected cell with OEM wrapper for 21700 is preferred.
mxyzptlk:
Hi, just now I get my March C8 XHP 35 HI (21700) a very well manufactured Flashlight, with a clear, beautiful CW. But there is a problem, the batterytube has a diameter of 21,6mm, which is very tight, so my Sofirn and LiitoKala batteries do not fit. Does anyone have an idea which batteries could fit?
mxyzptlk
(mxyzptlk)
September 19, 2019, 3:22pm
96
Thank you!
I just ordered some Samsung INR21700-40T 4000mAh - 35A, I think they will be good.
mxyzptlk
(mxyzptlk)
September 19, 2019, 6:47pm
97
Would anyone be so nice and could explain to me how I can set the individual groups.
My English is not so good that I can understand what is meant with:
>through the 3 stars on the back of the short circuit, you can set them to<
What is meant with 3 stars and what is the back of the short circuit?
Thank you!
Regards
Daniel
80T
(80T)
September 19, 2019, 8:00pm
98
mxyzptlk:
Would anyone be so nice and could explain to me how I can set the individual groups. My English is not so good that I can understand what is meant with: >through the 3 stars on the back of the short circuit, you can set them to< What is meant with 3 stars and what is the back of the short circuit? Thank you! Regards Daniel
The XHP35 boost driver does not have the 3 stars on the driver, thus no mode groups. Only the 7135 drivers have the 3 extra mode groups, like the XP-L HI and XM-L2 versions.
mxyzptlk
(mxyzptlk)
September 19, 2019, 10:51pm
99
Now I understand, thank you for the explanation!
Kind Regards
Daniel
I still didn’t receive any code. Freeme, are you ignoring me for some reason? :-(
mbp
(mbp)
September 24, 2019, 11:14pm
101
Sent PM, I would like a code
