Fin17
(Fin17)
September 13, 2019, 8:24am
1039
Fin17:
Probably you used this coupon earlier.
F7BG coupon has been operating since January.
Coupon limit increased to 5 times for each customer.
TexasToasted
(TexasToasted)
September 13, 2019, 11:51pm
1041
I like that red splatter paint look on the Xanes 3320. Ordered one for Halloween
Nicolicous
(Nicolicous)
September 14, 2019, 10:29am
1042
red splater looks photoshoped.
doubt you get what it looks in the image
RapidLux
(RapidLux)
September 17, 2019, 7:18pm
1047
Do you have code for Xiaomi Nextool Flagship Pro 16-IN-1 Pocket Multitool?
Thank you!
dnei519blf
(dnei519blf)
September 18, 2019, 2:15am
1048
Hi Fin17,
Is there any coupon for Convoy S2 UV flashlight with LG 365 nm LED and 7135*5 driver?
Thank you so much!!
d_t_a
(d_t_a)
September 18, 2019, 8:36am
1049
Does this mean the X8R-C (bigger head) head portion can be bought stand-alone?
Another question (in case some may know insider info…)
“Eagle Eye” brand seems to be relatively recognizable (EE X2R I think is a good flashlight, very similar to the popular Convoy S2+).
I remember seeing that the name got changed to Rixingguang (direct translation from Chinese is “Sun-Stars-Light” as per some sources).
And then now, it got re-branded to “Mezzol” — I wonder if that name means something?
Fin17
(Fin17)
September 18, 2019, 2:58pm
1050
I saw a separate head on Aliexpress:
http://bit.ly/2miduvL
Sorry i’m new to banggood but can you only use 1 coupon code per order?
neBstress
(neBstress)
September 18, 2019, 6:17pm
1052
Hi eyespeakbraille,
Yes, only 1 coupon per order.
Fin17
(Fin17)
September 18, 2019, 7:37pm
1054
BlitzWolf® BW-P9 10000mAh Power Bank
with Fast Charging, Dual Input and Output
for iPhone, Samsung, Xiaomi, Huawei
$13.99 - with my exclusive coupon code BGfin1701
Feature:
PD 3.0 Protocol
The latest universal charging protocol, charge faster and smarter than ever before.
18W Max Dual Output(Type-C + SUB ) and Input(Type-C + Micro)
Compatible with PD3.0,PD2.0, QC3.0 & QC2.0,It only takes 4h to complete 10000mAh at 12V/15A(Max).
Reliable Multi-layer Protection
Reassuring Over-charging Protection, Over-charging Recovery Voltage, Over-discharging Protection, Over-discharging Recovery Voltage, Over-current of Discharging, Over-current of Charging, Short-circuit, and Temperature Protection.
Specification:
Brand
BlitzWolf®
Model
BW-P9
Color
Black
Capacity
10000mAh
Battery Type
Lithium Polymer Battery
Ports
USB A + Type C + Micro USB Ports
Power
18W Total
Input
TYPE C/Micro USB Input:5V=2A,9V=2A,12V=1.5A
Output
TYPE C Output: 5V=3A,9V=2A,12V=1.5A
USB A Output: 5V=3A,9V=2A,12V=1.5A
Fast Charging
Type-C Input: Compatible with PD3.0 PD2.0
Type-C Output: Compatible with QC3.0 QC2.0 PD3.0 PD2.0
USB-A Output: Compatible with QC3.0 QC2.0
Size
139*70*15.5mm
Net Weight
200g
Weight
230g
Certifications
CE, FCC, RoHS
scosgt
(scosgt)
September 18, 2019, 7:52pm
1055
I bought one of these. It is very nice BUT
The USB cable that is included does not support enhanced charging. (Quick charge).
Must use a different cable.
d_t_a
(d_t_a)
September 19, 2019, 6:25am
1056
The Xanes XT02 looks very similar to a Convoy S2 or S2+.
I wonder what tint is the SST20 LED on that unit? 4000k high-CRI (probably not, based on the lumens values) so maybe 6500K?
Also: MT40 appears to have a better price when using your ‘BG13th’ code…
Fin17
(Fin17)
September 19, 2019, 9:25am
1057
Hi!
See the first post of this thread
