Its been a long wait, i am very excited itās almost done!
Do we thin o a 30q would suit this light, or weāre best with sofirn battery?
I use 30q in my q8, and armytek lights.
A 30Q would be about perfect for balance between cost and capacity for a high drain cell that can both be used in the Q8 and BLF Lantern, if they stay in pairs of 4.
TK - Iāll shoot you and DBSAR the full color logo files I have if you want them for the manual.
Speaking of the manual, Iāve been trying to condense it into something easier to fit on the back of one or more LT1 battery wraps. Does this look accurate so far?
Donāt mind me - I have no idea why the formatting is all janked up - working on it
1 = click, release
1H = click, hold
2 = click, release, click, release
2H = click, release, click, hold
etc
From Off
. 1 On
. 1H Ramp Floor
. 2 Ramp Ceiling
. 3 BattCheck (2 clicks to cycle Sunset-Beacon-BattCheck)
. 3H Strobes (2 clicks to cycle Candle-Bike-Party-Police-Storm)
. 4 Lockout (3 clicks to cycle Aux Off/Low/High/Blink)
. 5 Momentary
. 6 Muggle
. 7 Aux Off/Low/High/Blink
While On
. 1 Off
. 1H Ramp Up
. 2 Turbo On / Back
. 2H Ramp Down
. 3 Ramp Smooth/Stepped
. 3H Tint Ramp CFG
. 4 Ramp CFG
. 5 Manual Memory
. 5H Auto Memory
In Beacon
. 4 Beacon CFG ā Click N times for N seconds per flash
In Ramp CFG
. 4 configure
. Click N times for Floor level
. Click N times for Ceiling level
. Click N times for number of ramp steps (step mode only)
In Candle
. 3 Add 30 min to timer
It seems to use nearly the same LEDs as the BLF LT1 lantern (LT1 plans to use 2x LH351D 2700k + 2x LH351D 5000k); this teaser color-temperature-mixing EDC flashlight is supposed to use 2x LH351D 2700k + 2x LH351D 6000-6500k.
Probably transfer the Anduril firmware to an EDC flashlight?
Thatās an interesting technology transfer. The hardest part is probably transferring the LT1 driver design into a smaller footprint. Then again, if their engineers were looking ahead, thereās no reason they couldnāt have designed the LT1 driver from the start to fit in other shells. Hmmmā¦
Iām not sure of their market though. How many people outside of the enthusiast community will really care? Wellā¦ maybe photographers who want portable fill lighting they can match to ambient.
It could be possible that they are wanting to try the LT1ās tint ramp design-concept in a flashlight form after learning how well the LH351 series works with the tint ramp high-CRI range. I like the idea of that as a flashlight too. If Toykeeperās awesome Andruil-LT1 firmware was incorporated in such a flashlight, i would definitely be interested in one myself. :+1:
They posted a teaser video for that a while back. If I understand correctly, what happened was:
BLF sent a lantern driver design to Sofirn
Sofirn interpreted the design as a guideline, and made their own version of it
BLF insisted that Sofirn use BLFās original design in the lantern
Sofirn still wanted to use their version for something, and scaled it down to use in a smaller light
Otherwise, I havenāt really heard anything about it except the teasers Sofirn posted. I donāt know what firmware it uses, or if it is reflashable. I like the design, but it would have been nice to be included in the process since itās directly based on BLFās designs.
Too late to get this into the LT1, but for the LT2 it might be interesting to potentially use the same pogo pin layout as the D4v2 for software updating.
The reprogramming pins are in the LT1, not sure if the pin layout is identical, but would be surprised if it was not. I think the programming pins are at 3 oclock in the picture.
