I use the autolock feature in this state for two weeks now on a D4S and FW3A. Works without issues and especially with the FW3A it is nice because I can always grab it and put it in my pocket without checking if it is locked or not.
Anything that uniquely identifies the current firmware version would be acceptable IMHO.
Wouldn't YYYYMMDD be enough to look up the firmware in your repository?
I think this is an important feature to have, esp. for those who don't own a reflashing kit. If you didn't flash it yourself there's no way to know the exact firmware the light came with.
Use the ‘bzr revno’ command, or a history visualization tool like ‘bzr log’ or ‘bzr qlog’. More generally, the ‘bzr help’ command has an overview of available commands and other documentation.
To make a revision number meaningful though, it’s necessary to know which branch it’s on. Like, “trunk r236” is very different than “fsm r236”. But “fsm r236” and “trunk r188.1.48” are the same thing.
Note that “stable” is usually not the same thing as “latest”. Stable is usually behind, specifically missing the latest changes.
In particular, I’d suggest using the fsm branch instead of trunk if you’re doing anything with FSM-based interfaces like Anduril. It basically serves as a stable (ish) branch where all FSM-related changes land, as opposed to trunk which is a stable branch for the entire repository… and thus farther behind.
there are different pin outs from one supplier to another for those RGB LEDs, also footprints are not always the same
so you better know exactly which one is identical to the original ones
I must say I originally speculated the optical programming of the 371D to be a bit gimmicky but after using it a dozen or so times it’s actually pretty cool.
Being able to configure Anduril’s dozen options all at once would be very cool. You could even supply a link to newbs with an entire config they cant figure out. From a MFG side they also used it to throttle a few features back that would potentially lead to customer dissatisfaction but could still be overriden by the user by special means.
I’ve probably done it 15-20 times and as far as I could tell it accepted the settings every time. I would probably not want this to be the only way to configure it but if it was an additional way to configure and maybe a few select settings reserved as the “only” way to get to them that would be fine.
