Pete7874
(Pete7874)
September 15, 2019, 12:45am
1844
Rexlion:
The Tenavolts kit came today (Prime delivery van, how slick is that?). One of the 4 cells tested 0 volts out of the box. :rage: The others tested 1.54-1.55V. I thought, this one cell is probably toast, and if so I’m sending the whole thing back. But after charging fully (blue light turns off when done) I set the cell up in an old ITP C7 on high, and it’s been putting out good light for nearly an hour now, so I guess it’s going to be ok.
There is a protection circuit inside. If it trips, it cuts off voltage. Putting it back on the charger resets it, I believe.
What’s interesting, though, is the way these cells act in a light that has step-down regulation. I put one in a Zebralight SC5W and it only put out about 200 or so lumens instead of the possible 500… and within 30 seconds it had stepped down to maybe 5-10 lumens. The flashlight didn’t know what to make of it. Not enough current, I guess.
These cells were not designed to deliver lots of current - going above 1.5A will cause the internal buck converter to overheat and shut down.
decypher
(decypher)
September 15, 2019, 10:30am
1845
https://www.vipon.com/product/4492232-Moobibear-COB-LED-Work-Modes-Portable-amazon-coupons
This coupon seems to work for both models of this “work light”. The rechargeable USB one I was able to get out the door for 6.XX tax included. The AA version is even cheaper. I’ve found these type of work lights are pretty helpful when puttering around in the basement or when the lights go out.
Passing along in case someone else finds it helpful.
weklund
(weklund)
September 15, 2019, 11:33am
1846
Nice … I paid $5.88 delivered to my front door with Prime. Looks like a great deal.
Review:
Many Thanks for the heads up.
Pete7874
(Pete7874)
September 15, 2019, 1:04pm
1847
Nice. I ordered both for $11 total. Thanks for sharing.
Pete7874
(Pete7874)
September 15, 2019, 1:07pm
1848
Lightbringer:
Reverse-charging is when one gives up the ghost, and the other cells happily keep pushing current the wrong way through it.
Output cap, blocking diode, anything on the output of the buck regulator might end up frying unless the mfr took steps to keep that from happening.
I hear ya. Product description states: “Integrated 3-in-1 safety chip: Extra charge, discharge and short circuit protection, no over-charge, damage to lithium core or extreme temperature,” but how that works in practice is anyone’s guess.
Pete7874
(Pete7874)
September 15, 2019, 8:25pm
1849
What do you guys think is the source of power in this rechargeable one? Two 18650 cells? Three 18650 cells? Something else?
decypher
(decypher)
September 15, 2019, 9:10pm
1850
If the ad is to be believed, its 6000mah. Its likely a pouch pack. if we are lucky its 2x18650. Given the thickness, I’m inclined to think its a pouch.
moderator007
(moderator007)
September 15, 2019, 10:57pm
1851
Anyone got a code their willing to share for this COB work light?
You can PM me if you prefer. I could really use one of these, thanks.
fluke
(fluke)
September 15, 2019, 11:06pm
1852
Thanks.
I got the rechargeable version shipped to the UK delivery and taxes and import duty for $11 equivalent.
BillyBobJoe
(BillyBobJoe)
September 15, 2019, 11:27pm
1853
Its showing like $11 for me.
moderator007
(moderator007)
September 15, 2019, 11:38pm
1854
You have to use the vipon code at amazon and put it in the promotional code box at checkout to get the discount.
Unfortunately the code want be available again for about 13 hours.
Thanks for the tear down and shot of the pill. the shelf looks like it wasn’t a solid piece but tacked on afterwards.
weklund
(weklund)
September 16, 2019, 4:39pm
1856
Snagged one. Many Thanks …
Vipon coupon code: 9DLB-6PT7EF-RRX6AE
decypher
(decypher)
September 16, 2019, 5:19pm
1857
I stand corrected. The light has a 3x18650 wrapped pack in it. It is indeed 6000mah 3.7v.
Pete7874
(Pete7874)
September 16, 2019, 5:41pm
1858
You opened yours up?
I’m going to run a discharge capacity test when I get mine.
Wait… what?
The vipon code for the moobibear(!) is 11.27, but it’s listed on amazon at 10.99, straight-up.
What’m I missing, and how youse get ’em for 5-6bux?
Charmast uberpowerbank:
https://www.amazon.com/dp/B07SW6M1PX
vipon code brings it down to 20, 5% coupon knocks it down a bit more. Got mine for <20bux out the door.
Ah, here we are…
https://www.vipon.com/product/6635984-Portable-Charger-Power-Charmast-High-Capacity-amazon-coupons
Go crazy…
Pete7874
(Pete7874)
September 16, 2019, 6:58pm
1861
Lightbringer:
Wait… what?
Ignore the displayed pricing and apply Vipon code anyway.
decypher
(decypher)
September 16, 2019, 7:00pm
1862
Of course I opened it. It had screws. Isnt that what you are supposed to do with something you just purchase? Open it up and see whats inside/how it works? Thats how I grew up at least.
Ran out for the day, so I gots ta wait.
