You may have missed the third dimension. 26650 is 26*26*65 and 21700 is 21*21*70. (with rounded corners). Volume is directly proportional to lengh and to a square of diameter. So 21700 is 70% of 26650. And capacity / volume? It may get close at certain discharge levels but most of the time 21700 wins.
It’s just a matter of what constant do you multiply by later, pi or pi/4. So it’s directly proportional either way. And the constant goes away anyway when we express volume of one cyllinder as a fraction of volume of another.
I actually used an online calculation that allowed plugging in the cylinder’s dimensions and gave a total volume. (Already knew I didn’t miss anything. )
Most of the time? Really? So 4500 mAh is not 50% more than 3000mAh? I have run lights on both the Golisi Gold 26650 and Samsung 30T 21700, I know what each actually gives to a light with high demands, and I’m familiar with how long each cell can run a 23,000 lumen light, so I really don’t see the theoretical point when I have actual results before me… I have the new HOhm Run 3000mAh 21700 arriving today, they claim a constant 39.5A and pulse 48A, so I will use it to feed a hungry emitter and see how it compares to the 30T and Golisi Gold. The CFT-90 can take it, regardless of what the cell can do, so it should prove interesting… (yes, I’ll also test the HOhm Run 21700 in said 23,000 lumen light and see what it’s 17 emitters have to say)
Tweaked my pretty blue D4S to take an 21700 today. Only getting 5360 lumens so I’m not sure it was worth the hassle. What I did was remove the tail PCB and then shaped a copper disc to fit into the magnet space. Removed the Beryllium spring from the PCB and soldered it to the copper disc. Then went out to the lathe and cut an aluminum spacer to ground the battery tube to the tail cap. Only needed to be 1.34mm thick so it was a lot of hot for the little bit of part. lol
Hank seems to sell V1 and V2 on the same page now, based on whether the customer chooses RampingIOS or Anduril. If I recall correctly, the differences are:
D4S V1:
RampingIOS V3
FET+3
Attiny85
Single color aux LEDs
D4S V2:
Anduril
FET+3+1
Attiny1634
RGB aux LEDs
The physical design of the light seems the same though, probably because Hank got it right the first time. Aside from the overall size and weight being a bit much for EDC purposes, I think the D4S is probably the best design in Emisar’s product line-up.
I still don’t have a blue one… but I probably should.
It comes with RampingIOS V3 or Anduril. RampingIOS V3 is basically Anduril with a few things removed or rearranged.
To quickly tell which is which, make sure the light is off and then do a “click, click, hold”. In other words, click 3 times but hold the third click for a second or so. If it goes into a candle-like mode or some sort of strobe, it’s running Anduril.
Anduril has a tactical strobe and a motion-freezing strobe, and both have adjustable speed. There’s also a bike flasher with adjustable brightness, which I’d recommend for crosswalk purposes.
RampingIOS has no strobes.
The RampingIOS version has a single-color aux LED board, and the Anduril version has a RGB aux LED board. It’s different hardware — a different driver and a different aux board.
FET+3+1 has lower and more efficient low modes, and the highest regulated level is a bit higher. It also seems to help the thermal regulation algorithm a bit. It’s a definite upgrade.
However, I doubt it would be a very noticeable difference during daily use.
So you must have made some mistake. 21700 is 24245 mm³ and 26650 has 34510 mm³.
Yes, really.
I don’t see HKJ test of Basen 26650 but I see one from Mooch:
About 4050 mAh at 15A discharge.
Compare that to 30T which delivers nearly 3000 mAh at 30A:
And note how Mooch doesn’t provide internal resistance of this 26650 cell but rates it as capable of 23A. Yet it rates 40T as 30A. Just like Molicel P42A.
Compare the 26650 discharge curves above to that of Molicel:
26650 sags to 3.15V at 30A while P42A stays above 3.55V.
So…P42A is significantly more powerful and has 5% lower capacity at 15A…
I suppose you mean 4300 mAh? Here we can use the HKJ comparator.
8% capacity improvement at 10A and 9% at 20A. And still higher internal resistance (0.02 vs. 0.03). Again, that’s compared to P42A.
Charts and numbers, real world proves a different thing.
So I tested again the Basen and threw in the comparatively new 21700 Samsung 40T. And got a surprise! On my 17 emitter Ham’r flashlight with 5 drivers one cell testing shows the 30T to deliver 30.3A. The Golisi Gold 26650 can do 27A. By comparison the Basen does 21.9A and the surprise comes from the 40T, it bested the 30T with a huge 32.3A draw!
This is a heavily modified Q8 than I normally run on 4 Samsung 25S 18650’s to the tune of over 23,000 lumens.
Back to the original question, why ask Hank to re-tool an existing design for a new cell versus asking him to design a new light around the relatively new cell? Re-tooling for a quarter inch of space seems unlikely.
I was actually never all that impressed with the Shockli 5500 in my lights. For a time the black and gold LiitoKala had me buying more, but the Golisi Gold changed that. The Shockli cells I had were good performers, no doubt, but not game changing or head of the class performance wise.
But, in interest of staying up to date earlier today I ordered a pair of the new Sony (Murata) VTC6A 21700 rated for 4100mAh and 40A continuous. We’ll see…
