Neven, is your website down for maintenance? I’m struggling to get it loaded.
Hosting provider issues, I hope they will fix that today.
It should work now.
Thanks it’s working…
The server is up but the store is not accessible.
It's back now, but until some updates are done I'm not sure how long it will work (again), so if you plan to order, it's good to do it now.
After some updates web is working stable now.
Luxeon MZ (on all PCBs), Osram IR and Luxeon IR are on clearance sale:
https://led4power.com/product-category/leds1/lumiledsluxeon/luxeon-mz-4x2mm2-die/
https://led4power.com/?s=4715as+osram&post_type=product
Hi Neven, your lighted switch boards are 16.5mm in diameter. Can I sand 0.5mm off to make it fit in a Convoy T1?
Yes.
What’s the maximum I can safely shave off?
Switch pad that's connected to central pad/spring is closest to edge, so that's the limit.
I was able to get some additional CULNM1.TG LEDs, but not much, listings are updated.
Thanks
Any news about new drivers?
And now on a Q8 board as well
Any news on the Boost HX ?
There was listing for 4xCULNM1.TG before, maybe you've missed it because it was on second page.
No news regarding HX.
In development.
Can you change the software in ld-b4? 10 clicks to enter the configuration menu is not enough for me. Very often I accidentally enter this. Can you increase the number of these clicks? for example up to 20?
You can try to enable password for time being. I have had this problem but only right after building light where I am testing everything. In normal use I dont bother to enable password cause I find I dont run into the problem unless I am quickly running through testing and scenarios.
