a ways back, and as expected, you need to scrape them a few times to get them going (protective coating or somesuch), and then they spark beautifully.
But after a while, you scrapeā¦ and scrapeā¦ and scrapeā¦ and scrape, and end up with a small pile of splintery silver-colored shavings, but not a single spark.
The main bar seems to be plain Mg or other soft metal, but with the black coating āpaintedā on. After the coatingās scraped off, just the Mg (if thatās indeed what it is) is left, and it might very well be flammable with enough coaxing (like a blowtorch), but no sparks are forthcoming anymore.
You may have the less than optimum variety.
From my knowledge (only know from what I read in books) the Swedish firestarer is the one , all the rest are copies
Iāve been trying it with the come-with scraper thatās tethered to it. Worked fine all along.
In fact, I just tried it now with the scraper, and on virgin area on the bar. Scraped through the black coating, put quite a few metal shards in my slippers :person_facepalming: , but not a single spark.
Good thing I donāt need to start a campfire out in the woods or anythingā¦
I scraped off the coating from the end, and sure enough, thereās one strip (an inset smaller-diameter rod), and the rest is just Mg. With the āpaintā on everything, that part was obscured.
With theyād include, well, a clue, at least. :laughing:
Hey, thanks! Now I can go starting firesā¦ (Umm, wait, not the way that sounds.)
If you have a flashlight you could ācarefullyā use the battery to light up fine steel wool with dryer machine lint to start a fire or you could also carry a 9v battery.
One useful fact I learned from camping in the rainy Pacific Northwest.
Even in the rain, if you dig down through a rotted conifer stump, you will probably find some chunks of wood saturated with resin down among the roots that will work quite effectively to get a fire started.
I have a few of these. Further to what Oli posted, the idea is youāre supposed to scrape off some of the magnesium into a small pile of shavings and then ignite them with a spark from the striking surface (or āflintā).
Used that way they are ok, but good luck trying to do that in any kind of breeze.
That is true for flint and steel, but not for ferro rods. Using eye protection you can even scrape with a sharp but strong piece of broken glass, and still get as many sparks.
There are two types of ferro rods. Some hard ferro rods are LMF (Light My Fire) and Strikeforce; some soft gob spark rods are nano striker and firesteel.com. People who rarely use them often like the soft ones since they throw gobs of sparks. People who use them a lot often like hard ones since they last much longer and work just as well with proper technique. There are exceptions, so each to his own.
And there are cheap ones that do not work well, if at all. Take a back up method and enjoy your explorations in the woods!
