I like that red splatter paint look on the Xanes 3320. Ordered one for Halloween
red splater looks photoshoped.
doubt you get what it looks in the image
Do you have code for Xiaomi Nextool Flagship Pro 16-IN-1 Pocket Multitool?
Thank you!
Hi Fin17,
Is there any coupon for Convoy S2 UV flashlight with LG 365 nm LED and 7135*5 driver?
Thank you so much!!
Does this mean the X8R-C (bigger head) head portion can be bought stand-alone?
Another question (in case some may know insider info…)
“Eagle Eye” brand seems to be relatively recognizable (EE X2R I think is a good flashlight, very similar to the popular Convoy S2+).
I remember seeing that the name got changed to Rixingguang (direct translation from Chinese is “Sun-Stars-Light” as per some sources).
And then now, it got re-branded to “Mezzol” — I wonder if that name means something?
Sorry i’m new to banggood but can you only use 1 coupon code per order?
Hi eyespeakbraille,
Yes, only 1 coupon per order.
BlitzWolf® BW-P9 10000mAh Power Bank
with Fast Charging, Dual Input and Output
for iPhone, Samsung, Xiaomi, Huawei
$13.99 - with my exclusive coupon code BGfin1701
Feature:
Specification:
Brand | BlitzWolf® |
Model | BW-P9 |
Color | Black |
Capacity | 10000mAh |
Battery Type | Lithium Polymer Battery |
Ports | USB A + Type C + Micro USB Ports |
Power | 18W Total |
Input | TYPE C/Micro USB Input:5V=2A,9V=2A,12V=1.5A |
Output | TYPE C Output: 5V=3A,9V=2A,12V=1.5A USB A Output: 5V=3A,9V=2A,12V=1.5A |
Fast Charging | Type-C Input: Compatible with PD3.0 PD2.0
Type-C Output: Compatible with QC3.0 QC2.0 PD3.0 PD2.0
USB-A Output: Compatible with QC3.0 QC2.0
Size | 139*70*15.5mm |
Net Weight | 200g |
Weight | 230g |
Certifications | CE, FCC, RoHS |
I bought one of these. It is very nice BUT
The USB cable that is included does not support enhanced charging. (Quick charge).
Must use a different cable.
The Xanes XT02 looks very similar to a Convoy S2 or S2+.
I wonder what tint is the SST20 LED on that unit? 4000k high-CRI (probably not, based on the lumens values) so maybe 6500K?
Also: MT40 appears to have a better price when using your ‘BG13th’ code…
Hi!
See the first post of this thread
Hi!
Mezzol X8R-L. Code not working.
Thank you Fin17!!!
