I haven’t been edc’ing this much because I’ve had trouble pushing it in my pocket without pushing the button. But today I might have cured that. I’ll see how it goes.
The ‘extension’ is something i lathed up. Very similar to the washer pic below. It is just a press fit (finger press). Not glued because I didn’t know if i would like it. Been edc’ing for several days now. No issues at all wtih accidental turn on. The extension has also not slipped off despite only being pressed on finger tight. Definitely a worthy mod IMO.
battery ground on driver
the positive can be also used with MCU with a proper flashed Firmware to enable it
and don’t worry the board version with the outer lane to crack sometimes is fixed a long time ago
stupid fab placed the break drills too wide into the board
Thanks, still fine tuning it a bit. I need to get another o-ring for it though, forgot to take it out before I started removing the anodizing and it has now disappeared. The glass lens rattles a bit without it.
Picture makes it look pretty deep crenelations for what “meat” is left on that bezel. I guess it’s an illusion or there is more material than it seems to work with. Interesting!
Still a little bit left on the bezel. If you look closely to a stock bezel you can see there is two angles,the one closest to the lens is probably 1mm thick. I stopped at the top of that one.
Oh and I found the o-ring, it was on the garage floor.
I swapped the emitters for some LH351D’s (the venerable “dogfarts” at 5000k) and added an “ice blue” AUX board from Lexel. Some hand polishing and a bit of wax to keep it a little more shiny for good measure.
