Do you have code for Xiaomi Nextool Flagship Pro 16-IN-1 Pocket Multitool?
Thank you!
Hi Fin17,
Is there any coupon for Convoy S2 UV flashlight with LG 365 nm LED and 7135*5 driver?
Thank you so much!!
Does this mean the X8R-C (bigger head) head portion can be bought stand-alone?
Another question (in case some may know insider info…)
“Eagle Eye” brand seems to be relatively recognizable (EE X2R I think is a good flashlight, very similar to the popular Convoy S2+).
I remember seeing that the name got changed to Rixingguang (direct translation from Chinese is “Sun-Stars-Light” as per some sources).
And then now, it got re-branded to “Mezzol” — I wonder if that name means something?
Sorry i’m new to banggood but can you only use 1 coupon code per order?
Hi eyespeakbraille,
Yes, only 1 coupon per order.
BlitzWolf® BW-P9 10000mAh Power Bank
with Fast Charging, Dual Input and Output
for iPhone, Samsung, Xiaomi, Huawei
$13.99 - with my exclusive coupon code BGfin1701
Feature:
Specification:
Brand | BlitzWolf® |
Model | BW-P9 |
Color | Black |
Capacity | 10000mAh |
Battery Type | Lithium Polymer Battery |
Ports | USB A + Type C + Micro USB Ports |
Power | 18W Total |
Input | TYPE C/Micro USB Input:5V=2A,9V=2A,12V=1.5A |
Output | TYPE C Output: 5V=3A,9V=2A,12V=1.5A USB A Output: 5V=3A,9V=2A,12V=1.5A |
Fast Charging | Type-C Input: Compatible with PD3.0 PD2.0
Type-C Output: Compatible with QC3.0 QC2.0 PD3.0 PD2.0
USB-A Output: Compatible with QC3.0 QC2.0
Size | 139*70*15.5mm |
Net Weight | 200g |
Weight | 230g |
Certifications | CE, FCC, RoHS |
I bought one of these. It is very nice BUT
The USB cable that is included does not support enhanced charging. (Quick charge).
Must use a different cable.
The Xanes XT02 looks very similar to a Convoy S2 or S2+.
I wonder what tint is the SST20 LED on that unit? 4000k high-CRI (probably not, based on the lumens values) so maybe 6500K?
Also: MT40 appears to have a better price when using your ‘BG13th’ code…
Hi!
See the first post of this thread
Hi!
Mezzol X8R-L. Code not working.
Thank you Fin17!!!
Sorry I’m new to banggood. How does the pre-order work on banggoods. I’m interested in the edc18. Do I pay and wait? Or do they charge you when it ships like amazon? Thanks
Hi Fin, I have some Thorfire tg06s (upgraded version) on order using your code with Banggood. I just tripped over a video that someone has counterfeited that item. Can you advise if there have been any issues you are aware of with Banggood and know that these are authentic? https://www.youtube.com/watch?v=b0URYBzuoGA
