+1. It may well be that, statistically, more people prefer rosy Duv to green Duv, and maybe even to perfect BBL. But there must be a significant, if silent, minority, that, for general usage, prefers no Duv. Just as, I guess, I find myself in what must be a significant minority of people who prioritze CRI over tint. My eyes can compensate for tint variations, but there is no way to compensate for low CRI.
I would be surprised, but this matches what the researchers found. There was always someone who complained, no matter which tint was used… so no single choice will please everyone. However, the tints which had the fewest complaints were rosy to a degree of approximately –10 to –15 mduv.
It may also relate to the old idiom about rose-colored glasses. The phrase didn’t come from nowhere. Humans, in general, seem to find a touch of pink to be a bit more pleasant. Meanwhile, the counter-idiom of jade-colored glasses (or being jaded) refers to a more unpleasant outlook.
The ones I see discussed most often are the Lee minus-green filters. For example:
Compared to super green LEDs like the FB4 SST rosy ones look much better to my eye. However if I have a neutral tint (FD2 SST 20 and my good tint lottery 219cs in my D4) I find I much prefer it to a particularly positive or negative DUV.
To me the SW45K looks great next to super green LEDs, but when I compare it to any emitter that’s remotely neutral it looks pretty bad (even if it ends up making me perceive all others as “green”). It’s offensively rosy in the same way some are offensively green. That’s just my experience anyway ¯\/¯ The FD2 is as close to perfect as I’ve seen so far.
But… WHY? If the Daylight Locus is more green than the BBL, what is the supposed advantage of “merging” them this way? To say it another way: What light source is anyone measuring that they’d want to skew the “results” in this way?
Are you seriously complaining about the color of daylight? The advantages are numerous for technical and non-technical reasons. We evolved under daylight. We want our lighting to agree with daylight. Not have some weird discrepancy.
I understand that our eyes are naturally matched to daylight. But, why merge the lines? What advantage is it in scientific testing of “fluorescent” lights, including LEDs? The two lines exist already, and can be measured against, so what does this add that we need?
EDIT: BTW, I’m not complaining about daylight. That would be silly!
Again, studies pretty clearly demonstrate we don’t want that. It’s extremely useful to have a proper daylight reference in many situations, but it doesn’t mean it’s what people want for general lighting, especially at night. User preference is much more important than achieving the one true neutral tint.
If what Bob said doesn’t make sense, you may be confused. But this is not a bad thing. Being confused can be a very useful thing, if one is able to recognize it.
One day, students went into their physics class and the teacher showed them a large thick metal plate with one end very close to a fire and the other end a couple meters away. The teacher instructed the students to feel the metal plate, and they felt that the end near the fire was cooler while the end away from the fire was warmer. So the teacher asked the students to write down a guess about why.
Some students wrote things like “because of how metal conducts heat” or “because of how air moves”, but no one wrote “this doesn’t make sense” or “this seems impossible”. So no one got the right answer… which was that, just before the students came into the room, the teacher had turned the plate around.
The students failed because they did not notice their confusion, and thus ignored the most important clue they had.
Usually, when one is confused, it means that one has a false belief or a false assumption. The sensible way to respond to confusion is by trying to identify what that false belief is… and get rid of it.
In this case, I think the confusion may be caused by the false belief that humans in general want artificial lighting to be identical to daylight (or at least on the blackbody line). The available data on this topic indicates that most people actually do not want this, and instead prefer something a bit more rosy in tint. A perfect blackbody radiator may be ideal in a mathematical sense, but that does not mean it produces an ideal lighting spectrum for human use.
Or perhaps the confusion may be caused by the false assumption that Bob doesn’t know what he’s talking about. But he does, and he’s not confusing duv with CCT.
You are know TK, I’m getting tired of you deleting the relevant parts of my quotes to make me look confused. Let me quote that properly for you to read again.
