Test/review of Vapcell NCR18650 3400mAh M34 (Blue) 2019
Official specifications:
  • Model: NCR18650 3400mah 10A
  • Size: 18.3*65.3mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 3400mAh (0.2C discharge)
  • Min capacity: 3300mAh (0.2C discharge)
  • Weight: Max: 49g
  • Internal resistance: Max: 25mOhm AC 1kHz
  • Standard Charge: 1000mA, CCCV 100mA cut-off
  • Quick Charge Current: 2000mA
  • Max Continuous Discharge Current: 10A
A high capacity 18650 cell that can deliver a fair amount of current.
The two batteries matches very well.
The batteries gets too hot at 15A.
Conclusion
This looks to be a good high capacity cell.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
That’s interesting. Curves similar to the LG MJ1, yet slightly better most of the times, slightly worse than the NCR18650GA, most likely a tradeoff for improved cycle life. If Vapcell hadn’t told us already that it is “Tesla Panasonic NCR18650BG rewrapped” I would be at loss.
Thanks HKJ!
Thanks HKJ test the battery :+1:
Yeah 。, it is Tesla Panasonic NCR18650BG rewrapped :slight_smile:
Price is very cheaper than GA or 18650B
