Just purchased second …
Design: Nichia 219C 4000K
maybe you had a typo?
did you receive the first mail direct after you filled in the Form?
Ordered 1x SST20. Thanks Martin!
Ordered one of the Nichia 219C Thanks!
I’ve lost track of this project, so I ask: will the 18350 tubes available?
Thanks in advance!
When are these expected to ship?
The banggood app says the 24th is the expected ship date if that means anything.
still no YES for the short tube :(
Neal tries to find a solution for a limited run
Thanks ordered.
dimensions of the flashlight and runtimes in xpl version are known?thank you
@vresto, since it has the same driver and LEDs as the FW3A, runtimes should be the same:
Dimensions? About the same as the FW3A. A bit smaller.
Pretty much same as FW3A.
runtimes depend on the cell you use (type, age, temperature etc) and which of the 150 levels you choose ;)
i should receive a final light next week and will give all dimensions
that one has a pressfit optic
I was not told about other major changes
goddish….again the same problem…….please,what would be better? this Lumintop or this Amutorch:
https://www.aliexpress.com/item/4000187653275.html?gps-id=pcStoreJustForYou&scm=1007.23125.122752.0&scm_id=1007.23125.122752.0&scm-url=1007.23125.122752.0&pvid=783e3fd7-4ce2-4e73-82a1-341dded65385&spm=a2g1y.12024536.smartJustForYou_151867467.15
everything is similar…what will be brighter…
Don’t choose by which is brighter, go by user interface. This will determine if you like it or hate it.
low mid hi turbo is my mantra:)) more or less…no dimming) thats all:)
Thanks for the answer Martin!
I am honest, I will only buy this light in case the short tube is available! Other wise I will go straight forward just for the Emisar D4V2 (that I will buy no matter what)!
As usually, I am looking for the short tubes to have some versatility in length, and although I prefer thinner lights (14500s or 16340s) having this with a 18350 would be a pleasant light to carry!
Thanks and I will be looking for updates :+1:
Interested, please send me the code.
Will there be a short tube and a recessed button option?
