TENAVOLTS AA Lithium 1.5V rechargeable cells
From Illumn (and others confirming same):
Ni-mh cell:
Low: 20mA, 10 lumens, 20hrs+
Medium: 135mA, 60 lumens, 4hrs+
High: 500mA, 200 lumens, 1hr+
14500 Li-ion:
Low: 300mA, 90 lumens, 2.5hrs
Medium: 1000mA, 320 lumens 45min
High: 1560mA, 430 lumens, 30min
So figure maybe a half-amp-ish even at 1.5V vs 1.2V. Below an amp on high, at any rate.
I don’t mean this as an insult, but are you sure you had a fully charged cell? It’s impossible to tell except freshly charged, or empty and dead.
I have a dozen, all tested at 1.6Ah @ 0.5v, or slightly better. Good consistency.
I don’t get the specs. How does, say a 2000mAh NiMh pulling 500mA only run for 1hr+? Math doesn’t work out. Should be near 4 hours. That much inefficiency?
I’d expect the Tenavolt to go somewhat over 3 hours on high.
As soon as I opened ’em, I popped out the plastic thingy, loaded ’em all up, powered up the charger, spun each cell around ’til the bright part of the ring was on top, and let ’em burn. After a half-hour or so, poop! poop! poop! poop!, all 4 lights eventually went out. Charged, I presume.
NiMH is only 1.2V. It has to boost the voltage to the LED to 3.whatever. So if it boosts the voltage 3× to 3.6V, current would be 1.5A from the cell to supply 500mA to the LED, assuming 100% efficiency.
Granted, it’s the lousiest route as far as efficiency, going from 3.xV from the internal cell, down to regulated 1.5V, then back up to 3.xV to drive the LED. Still, I prefer the more evenly-spaced modes at 1.5V, even if not nearly as bright, vs all-bright directly from a 14500.
Besides, I gotta find something to use ’em in. :laughing:
Got a battery powered: nose trimmer, beard trimmer, 2xAA Sonicare travel toothbrush? Really perks up devices like that, small motors that are kind of laggy, especially as the batteries get old.
The only lights I put them in are small 2XAA or 4xAA motion lights I have all over the house. Some of them that I want to keep brighter and are harder to change out seem to do a bit better with these.
A minor point, but important to me, is that the battery grip in some of those lights is damn aggressive. I can shred the top edges of the cell prying it out, or break a fingernail (ouch!). Some cells I actually need a tool which can cause even more damage. The Tenavolt are a tad smaller diameter, much nicer and harder skin/wrap than any other battery I know (including Eneloops), and slipperier. They go in and out nicely. For a permanently mounted light near the ceiling I like that a lot.
The best cells I had for those particular lights were some REALLY old RayOVac 4.0 and Eneloops. They are getting tired and need replacing anyway. They have hundreds of cycles. Those old ROV have actually been amazing. Manufactured in 08/2011, I beat the snot out of them and most of them are still OK, not great, but still buzzing along. Good enough for stuff like that.
BTW, thanks for the efficiency explanation. Didn’t think about the multiple conversions going on. That would not help out at all.
After finding out the hard way just once, I’d stick a thread or thin string under the cell to help yank it out later if wedged-in.
But yeah, things that directly take 1.5V are what these cells are best suited for.
Well, that’s a [DUH!] moment. They put those in devices. I guess I could too. :person_facepalming:
The Tenavolt cell I took out of a xeno eo3 after it shut off running on high read 0.24V fluctuating wildly to about 0.60V. The tenavolt ran this light more like a 14500 than a eneloop - brighter with a lot more heat and shorter run time. In direct drive lights, the Tenevolts are great. The run at full brightness until they are almost dead when they start to dim and flicker. In most fully regulated lights, Tenavolts seem to run pretty much like standard eneloops.
Hmm, odd. Mine was going full tilt and then just shut off without warning. Try turning it on, nope, nothing. No flickering nor dimming.
I’d like some kind of indication, in fact. That’d at least give me some warning.
Alkaleak, lit right up. 14500, lit right up. Tenavolt, nope.
Recharged it, lit right up.
Have you not seen the completely flat discharge curves posted by HKJ? :slight_smile:
Oh, I’ve seen ’em, but still wish there’d be some kind of warning. It’s a bit disconcerting to be shaving your face and have the beastie just up’n’die as if you switched it off. Bad enough NiCd cells would do that over 5sec or so. Having it happen instantly is definitely a “Whoa, what happened??” moment.
The Xeno just shut off - I think the protection circuit kicked in.
Running tenavolts in a couple of flashlight/lanterns combos, a energizer weatheready 2AA and a life gear 3AA is where I got the dimming/flickering……thought it might have something to do with the multiple cells, but I had the same thing happen with a inova X1 which suddenly dropped from full brightness to a few lumens and soon started to flicker. I’m not sure what is going on, but this is what happened.
I think there may be some variation in cut-off. I’ve got some that simply go to 0v, and others that do kind of what you are saying. But, when it’s flickering, it’s done.
Could be chuggle. Ie, voltage under load when it’s spent drops too low, the circuit stops functioning, load drops to near-0, voltage rises, it kicks in ever so slightly for a “flicker”, then the cycle repeats ’til the cell’s so spent that it doesn’t come back on again at all.
Neighbor whose yard abuts mine has an idiotic spotlight in his yard, where the sensor must be in the beam or at least catching enough light from it. Turns on, sensor thinks, “Ooh, it’s light out!”, then shuts off 5sec or so later. Then, “Ooh, it’s dark out!” and it comes back on another 5sec or so later. And the cycle repeats.
All.
Night.
Long.
Think of the “flicker” as a very fast and thankfully very transient effect like this.
Is this still accurate for an Xtar X4? I put four in my charger before I read this thread and it seems to work….
I still have the proprietary charger so I can use that if it’s warranted.
Sorry for the necrobump
No, it doesn’t work. It may……seem…. to work with ……some…… chargers. You will get some charge, but the charger’s termination capability will be thwarted by the internal electronics. They are in control.
Tried what you are talking about with a number of multi-chargers. Nope.
Works fine with the proprietary charger.
I haven’t been impressed with my set of 4 Tenavolts cells. One would not hold a charge worth anything, and the others don’t provide much longevity per charge.
Wow. I sooo appreciate the info. I put them in the tenenvolt charger and the primary indicator was green.
I assume they are charged…? They will go back into the bathroom radio until ‘dead’ and then back to the factory charger. Tanks again!
Huh… they work fine for me. You MUST use the come-with charger. They need 5V full USB voltage, NOT 4.2V that’d charge Li cells. The latter almost certainly won’t charge the internal cell worth a damn.
In my Xeno, an alkaleak will gradually dim to the point of being useless. A Tenavolt will maintain full 1.5V brightness (ie, dimmer’n a 14500) right up to the point where it drops dead without warning. Decent runtime, too.
I agree with @Lightbringer. I have a dozen, all working almost continuously for a year+. No, they don’t have mega capacity, most being in the 1600mAh range. They don’t have mega amp output, being limited by the circuitry to ~ 1.5A output. But they do put out a pretty solid 1.5v until they drop dead. That is very useful for “some” applications. Mostly not needed though. Understand what you are buying.
Only worth the price on a GOOD sale, which I have not seen in ages. Current price is simply way too high.
+1
My Harmony remote loves them because of the steady 1.5V output. They last about 6 months in it on a single charge.
