hi, it is L M H. see that UI…
It will wait some days to prepare.Surely it is availble.
hi, see the pictures:
There is a thin silicon rubber ring aroud there. When I tighten the bezel, the ring will be pressed into the rubber position.So the bezel is fairly tight if you want loose it by hands. Surly, we have special tools to tight it. For most people, it is hard to loose. But, there is no any glue. There is also no glue under the MCPCB.
While if somebody want me to loose the bezel for you, surely,pls tell us in words. I can find it… Jaxman like make solid lights that you may can not disassemble…
Awesome. A must have.
hi there is no PTC thermistor—-the so called TC—-on the driver’s PCB.
a thermistor on a small PCB, I can t call it TC.
Looks good. How to order a nichia triple version ?
Yes how indeed!
Will there be an 18350 battery tube available?
Looks like all the LED choices currently available are above the BBL.
Huge Jaxman fan, though. I’ll probably end up with this one…
Ooh, I liked him as The Wolverine, too!
I’d like to get in on a Nichia triple as well.
Interested, please make an 18350/18500 tube!
Ordered the 4300K TIR Triple.
The pocket clip on this design/style of lights is one of the most important parts/details and yet you have a crummy snap on clip?
How about a ring clip secured between the head/battery tube/tail cap/battery tube…
Can you please reveal, whether the output drop is driven by temperature or time?
Thanks to all guys. I am hard to visit BLF these days. I dont know if it is because of nearing to the National Day-1st,Oct.
The Nichia 219C version has been issued on our store too.
We want produce the XHP50.2 version and another LG high CRI led too.
I will reply more when the net is better.
Hello Jaxman.
Have you though about getting Samsung LH351Ds?
Thank you.
Can the “key lights” be adjusted? Based on the UI I guess it’s not but thought I’d ask anyways. It looks really bright in this picture for what I’m assuming is an indicator light? Or is it supposed to be a “moonlight” kind of light?
That’s actually a pretty good point. I unscrew the tailcaps on pretty much all my lit-switch lights because they’re too bright at night, and having a brightness control for that, ie, very very dim as a locator, brighter for actually using it, would be a great idea.
I second this.
If the clip is secured, I’d buy without hesitation
hi,surely can buy it in China.
while I am some busy to do it. I will care it.
