Specifications Emitter:
One LED on a copper DTP MCPCB e.g.
Cree XP-L HI 7A (WW 3300K)
Cree XP-L HI 3D (NW 5000K)
Cree XP-L HI 1A (CW 6500K)
Luminus SST20 4000K 95 CRI
Nichia 219c (NW 4000K)
REFLECTOR: ORANGE PEEL Lens: Glass with anti-reflective coating Flux: ~1200 lm (XP-L Hi), ~700 lm (SST20) Intensity: ~40 000 cd ANSI throw ~400 m (XP-L Hi)
~28 000 cd ANSI throw ~335 m(SST20) Firmware: The FW1A uses free software called Andúril, distributed under the terms of the GPL v3.
Code is available from http://tiny.cc/TKAnduril
User interfaces: [1] By default the FW1A is set to use SMOOTH RAMPING.
Instant access to TURBO mode is also provided. [2] A more conventional STEPPED RAMPING UI is available if you like discrete modes level. You can choose how many steps you want. [3]MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets. To exit this mode, physically disconnect power [4] MUGGLE mode uses a reduced output. [5] It has an electronic LOCKOUT for safety, but acts also as momentary low light.Other functions: Battery check, sunset, beacon, tactical strobe, party strobe, bike flasher, candlelight, lightning storm
Battery: One flat-top or button-top 18650 cell. An unprotected cell is recommended. Max. length 66 mm. Cell is not included.Driver: FET+7+1 driver. Low parasitic drain while OFF Body: Aluminum with hard-coat anodizing Switch: Electronic tail switch Ingress rating: Equivalent to IPX7 Weight: Approximately 57 g without cells Size: 25.5 mm Ø head x 100.8 mm length.
i got 15 codes forAmazon.DEand 10 codes for Amazon.co.UK for my friends and members
(i can give out max 5 per day per shop)
here is how to get one:
* use my link toAmazon.DEor Amazon.co.UK to make sure you can buy them (put in cart so AMZ calculates shipping etc)
* send a mail to martin@m4dm4x.com
* betreff/subject: Sofirn SP70 KIT AMZ deal
* i answer with the code and date you can use it
i made a little video review for you a while back:
Can you please ask the manufacturer if they were to offer a NI40 with the RED SBT-90, too? Having a compact 1,500 lm flashlight with red light would be gorgeous.
For reference, Acebeam sells their K75 with the red SBT-90.
