There is a thin silicon rubber ring aroud there. When I tighten the bezel, the ring will be pressed into the rubber position.So the bezel is fairly tight if you want loose it by hands. Surly, we have special tools to tight it. For most people, it is hard to loose. But, there is no any glue. There is also no glue under the MCPCB.
While if somebody want me to loose the bezel for you, surely,pls tell us in words. I can find it… Jaxman like make solid lights that you may can not disassemble…
Thanks to all guys. I am hard to visit BLF these days. I dont know if it is because of nearing to the National Day-1st,Oct.
The Nichia 219C version has been issued on our store too.
We want produce the XHP50.2 version and another LG high CRI led too.
I will reply more when the net is better.
Can the “key lights” be adjusted? Based on the UI I guess it’s not but thought I’d ask anyways. It looks really bright in this picture for what I’m assuming is an indicator light? Or is it supposed to be a “moonlight” kind of light?
That’s actually a pretty good point. I unscrew the tailcaps on pretty much all my lit-switch lights because they’re too bright at night, and having a brightness control for that, ie, very very dim as a locator, brighter for actually using it, would be a great idea.
