Ordered S12 and FW3A Cu (separate orders)
Thanks!!!
Thanks!!!
The code is not working for the UNI-T UT210-E :-(
"Coupon is only used in special collection list and valid on over the specific value"
I don't get it.
Corrected.
Use right link >> UNI-T UT210E
Thank you Fin17! :-)
Ordered S12 and FW3A Cu (separate orders) :person_facepalming: Thanks!!!
Sofirn sp40 ordered yesterday!
Question what is the colour temperature CCT of Sofirn SP40 Headlights?? I mean their respective kelvin…
In Sofirn’s AliExpress store, they have the 5300k, 4000k and 3000k versions.
I think Banggood only has the 5300k version.
hasddie293:Question what is the colour temperature CCT of Sofirn SP40 Headlights?? I mean their respective kelvin…
Received this one yesterday. Definitely cold white, even beyond 6000K I think.
Thanks, I’m still waiting for mine but good to know. Not bad for the price I guess.
Is there a quick charg solar panel?
Unfortunately, I have not found anything like that.
Greetings
Got my Tomo M4 today.
VERY cool device!
scosgt -
which batteries do you use with this power bank?
I put some 30Q’s in that I had on hand.
BUT you don’t need high drain batts, Probably cheap ebay batteries would work fine, max output is around 2 A
I will try some *fire batts I have on hand to see how they do.
scosgt -
I put in some EBL’s from ebay
On the 1A slot it shows .96 charging my Note 4
On the 2A slot it puts out around 1.15
using the 30Q, it shows around 1.5 to 1.6 amps out.
So using a high drain battery will give faster charging. But the cheap batteries do work, and if you are running a device that only requires 1 Amp they would be fine.
Is it possible to get anniversary coupon for Nitecore TINI SS Tropical ?
