Archive topic - Banggood & Fin17
Sofirn sp40 ordered yesterday!
Question what is the colour temperature CCT of Sofirn SP40 Headlights?? I mean their respective kelvin…
In Sofirn’s AliExpress store, they have the 5300k, 4000k and 3000k versions.
I think Banggood only has the 5300k version.
Received this one yesterday. Definitely cold white, even beyond 6000K I think.
Thanks, I’m still waiting for mine but good to know. Not bad for the price I guess.
Is there a quick charg solar panel?
Unfortunately, I have not found anything like that.
Greetings
Got my Tomo M4 today.
VERY cool device!
scosgt -
which batteries do you use with this power bank?
I put some 30Q’s in that I had on hand.
BUT you don’t need high drain batts, Probably cheap ebay batteries would work fine, max output is around 2 A
I will try some *fire batts I have on hand to see how they do.
I put in some EBL’s from ebay
On the 1A slot it shows .96 charging my Note 4
On the 2A slot it puts out around 1.15
using the 30Q, it shows around 1.5 to 1.6 amps out.
So using a high drain battery will give faster charging. But the cheap batteries do work, and if you are running a device that only requires 1 Amp they would be fine.
Is it possible to get anniversary coupon for Nitecore TINI SS Tropical ?
UPDATE:
This unit is very sensitive to the USB cable.
I found a short cable that it likes, puts out up to 1.7A with the EBL protected low drain batteries, a little more with the 30Q (saw it hit 2A once or twice).
But with the right USB cable the cheap ebay batteries are fine for almost any purpose, the difference in output is small.
I also tried with a Chaselight rechargeable flashlight (micro), only draws .77A
Two scanners (Uniden 325P2 and Home Patrol 2) also drew less than one amp while running.
Gonna try a USB C light just for kicks.
USB C on an Astrolux EC01 starting at 3.9 Volts remaining show between 1.75 and 1.85 Amps so the cheap batteries work fine. I found a home for some batteries that won’t power my powerful lights.
See the first post of this thread.
Same price as was with anniversary coupon.
Hi Fin, any news?
Unfortunatelly it is not. With AC18 code it is 6 dollars more than the anniversary price.
There was another code that gave 50% off.
You can wait until 11.11
