Iāve noticed mine jumping a little. Part of it looks like normal stutter as it passes ramping points, but the really odd one is on ramping down. Sometimes it would ramp down a bit then jump right to Low. It only happened sometimes, and I havenāt figured out the pattern yet.
I have no problems coming out of Muggle mode and havenāt had to unscrew the cap to reset it.
Wait one ā Ramp Down is click, click-hold. The shortcut from Off to min ramp is click-hold. Maybe thereās a timing issue where it recognizes the Ramp Down command, but then thinks the continuing click-hold is a request to drop to min?
I wonder if this is a bug in an Astrolux fork of Anduril or a general Anduril weirdness?
@ToyKeeper - were you involved in the EC01 project or any Anduril customization for it? Is my guess anywhere near logical or possible with Anduril?
Hello,
I just received my EC01. Looks great and everything but it was supposed to replace my old Nitecore EA41 with XML2U2 and a direct comparison of these two lights disappointed me
The EA41 on high is much brighter and has a better throw than EC01 on turbo. Besides that - the EC01 gets hot after a couple of seconds while the EA41 remains significantly cooler for a whole minute.
Iām using a brand new and fully charged Samsung 40T 21700 cell.
I do not need more light than my EA41 produces but the EC01 cannot even keep up plus it gets hot and ramps down quickly. But, to be honest, I also looked forward how 3500 lumens look next to 1020 lumens.
Is there anything I can check or is it how it is supposed to work?
The EC01 was not designed to be a thrower. It outperforms the EA41 hands down, except for throw. If you want the EC01 to throw farther than the EA41, change the LED to a SST-40 5000K/6500K. On turbo, you will see a definite increase in throw over the EA41, and around 2100 lumens.
There is no way that the EA41 is brighter than the EC01. It sounds to me you are in muggle mode, or your EC01 is faulty. On max ramp the EC01 will be brighter than the EA41, and on turbo it will simply blow it out of the water.
Nitecore EA41 is a 1000 lumen flashlight? lol no wonder it can run longer but its no way near max turboā¦ for me i feel its just as bright on turbo as my convoy l6 cool white which does around 3500 lumens or whatever so it shows its really doing that much lumens the ec01ā¦ it getting warm is no suprise because the light is insane cute smallā¦
Nitecore EA41 has a bigger reflector but less lumens, the ec01 reflector isnt really bigger then a convoy c8 or smaller? but since the light does 3500+ lumens u get some decent throw consdiering its a OP reflectorā¦
Thank you for the hints. I ordered two EC01ās (one of them as a christmas gift for my father) and both perform the same. Muggle mode is off.
I do not have equipment to measure the output but it seems to me that both EA41 and EC01 produce roughly the same āamountā of light (EC on turbo, EA on highest mode) with EC being more floody (which I actually prefer) and EA giving much more throw.
The thing is that EA stays warm to touch for more than a minute while EC is unconfortable to touch after 20 seconds or so.
I will make a video during the weekend to show you.
What you say some some sense. Both lights light up a spot to the same degree, but the EC lights up a wider spot than the EA. The lumens to light up that additional area have to come from somewhere.
No no, the spot of EA is much brighter than the one of EC. You can clearly see EAās brighter spot when pointing at ECās spotā¦ if you know what I mean Iām just guessing that the āamountā of light both lights produce is roughly the same (EAās narrower but brighter spot vs. ECās wider but less bright spot).
Itās just higher candela, not higher lumens. So easy to think itās brighter if you donāt know the difference. My 800 lumen OSRAM White flat Convoy C8+ throws much farther than my 6000 lumen BLF Q8.
Thank you for the video. The specs on this light look so good: price + charging + lumens. It also looks very good on video reviews. I wish Astrolux had better build quality + supportā¦ s43s & EC01 would then seem like good gifts.
Flashaholics , and d_t_a next to MF01 mini. It looks so bright in the grassy field.
So tempting at $25
This is too technical for me, but is there a chance the problems discussed are related to the MF01 Mini problems of incorrect voltage reading, and temperature calibration?
Some are rated at 3.6volt, others 3.7volt. Does this make a difference? I do realize that they will be charged to roughly 4.2 volts.
Can the EC01 reach it's max performance with the 10Amp 50E, or is 10A not enough? I ask as it has the highest capacity of the four.
If the 50E is not sufficient, then the Xtar appears to have the best specs of the remaining three. Would the Xtar be the best choice for brightness and capacity?
Or, would you suggest the Sammy 40T? (or 30T....although the 30T is more expensive than the 40T for some reason)
Lastly, would an IMR battery have any advantages over INR? I think I Saw a Liitokala IMR that was up around 4000mAh and 40A.
Received my EC01 yesterday, and I am disappointed to see the beam is a very warm color. I ordered the cool white 6000-6500K, but clearly got a 5000k model. The product box has a label that states 6000-6500K, and that label was put on rather sloppy, so I am thinking somebody at the factory was in a hurry and put the wrong label on the box, causing the issue.
I sent a message to the seller on Aliexpress, so I am hopping for a resolution within the next day or two.
