Managed to unscrew button bezel, but cant get button out. There is a lot of glue and I used metal needle with slightly bent end, but it doesnât move when I pulled with a lot of force. I am afraid to damage something.
By the way, does Sofirn sell spare drivers and buttons in case I damage mine? Or maybe there are non OEM buttons and drivers that will fit?
UPDATE: button is out. Will try nail method now.
UPDATE2: driver is out. New firmware flashed. Everything works!
NarsilM and Anduril handle parasitic drain so it's quite low, #'s published in many places, unless there's some real problem with the driver electronics.
If the ramp ceiling is set to turbo, momentary mode will also be able to run at full brightness. It simply uses the last-ramped level.
As long as the button LED is off or in low mode, it should have parasitic drain lower than the cellsâ self-discharge rate. The button LEDâs high mode could drain a set of cells in about a year though.
I finally bought the LH351D Anduril version. Itâs a lot heavier than I expected. I donât have a Q8 and donât look at weight ratings so donât really know what I was expecting
Overall feel is great, I love the simplistic design, although a SS bezel would be a nice feature. My only complaint is that the fins are pretty sharp. Same with the SP10S. Some chamfering would make them feel more comfortable and refined.
First thing I did was to open her up. I firstly tried soldering a wire and pulling but that didnât work. In the end I went through the switch. Turned out to be pretty easy and wish I tried that first. Hardest part was unscrewing the switch without damaging it.
Iâm now left with solder over the contacts from my initial attempts. Iâve tried removing it with solder braid and flux. Most of it got removed but some remains and has kinda just smeared into the grain. Any tips on how to completely remove it? Do I just need to get better solder braid?
Iâve played around with the light some more and the voltage reading is off. Charging is ok and terminates at 4.2v but checking through the UI reports roughly 0.1v higher. IIRC the real value can be obtained by flashing some code to get the values to then tweak the âfudge factorâ in Anduril?
I didnât get a manual, should the switch led indicate low battery? Or does it only light up red when charging?
hodor, djozz's suggestion is good but it should also work with solder braid and flux. You need to make sure the soldering iron tip's heat imbues well into the solder drops and the driver's brass ring, this means using a big tip with plenty of contact surface over the copper braid. The iron tip may need a very slight soaking, and of course plenty of flux over the surfaces.
I still have some solder on the ring on mine, I used a braid to get most of it, then used a wide flat soldering tip to smooth the rest of the solder so itâs just a very thin layer. Works fine.
On my 2nd SP36, the other night I tried the heavy gauge wire and pulling, as I did the 1st, but couldn't get it to budge this time. So, I removed the switch and hammered lightly on a pointy tool, like a thin ice pick, and it easily popped out. I knew though what part of the driver I'd be damaging, knew it was a safe area away from any components. It did get scratched up but no harm.
Re-programmed the NarsilM v1.2 with v1.3 and calibrated the voltage and temps so readings are now accurate.
Here are some measurements of the SP36 and SP36S that I bought during the 11/11/19 sale, taken with the Texas Ace lumen tube calibrated with Maukka lights:
Sofirn has the nasty habit of gluing everything, but from the inner threads, the driver would be 42.75mm.
The aperture is 40mm so give some 1 to 2 mm more for the reflector OD.
