A L-style shape chest and table lamp from Jaxman named E1
Thanks to all guys. I am hard to visit BLF these days. I dont know if it is because of nearing to the National Day-1st,Oct.
The Nichia 219C version has been issued on our store too.
We want produce the XHP50.2 version and another LG high CRI led too.
I will reply more when the net is better.
Hello Jaxman.
Have you though about getting Samsung LH351Ds?
Thank you.
Can the “key lights” be adjusted? Based on the UI I guess it’s not but thought I’d ask anyways. It looks really bright in this picture for what I’m assuming is an indicator light? Or is it supposed to be a “moonlight” kind of light?
That’s actually a pretty good point. I unscrew the tailcaps on pretty much all my lit-switch lights because they’re too bright at night, and having a brightness control for that, ie, very very dim as a locator, brighter for actually using it, would be a great idea.
I second this.
If the clip is secured, I’d buy without hesitation :slight_smile:
hi,surely can buy it in China.
while I am some busy to do it. I will care it.
Nichia high cri 219c version is ready.https://budgetlightforum.com/t/-/58576#comment-1562629
What is the driver size? I will want to replace driver with something from Lexel (w/ Anduril) most likely. (BLF host version :innocent: :+1: :innocent: :+1: )
BLF host version would be cool
Very very very cool
+1
I’m sure it could be adjusted if you can solder microscopic resistors in place :confounded:
Interested in a host too.
hi guys, I am so hard to visit BLF.
18350 /18500 tubes are in production.
the driver is 17mm
It seems that the BLFers are intersting the host in every new Jaxman models release….
if really necessary, and promise have the skills of assemle it I think I can provide host for BLF.
my email: zx.bao@foxmail.com
wait you.
Will email as soon as 18350/500 tubes are available. Please keep us updated, thank you!
ok. I will tell you here.
Now there is a change on the way of fix the MCPCB on E1. we have decide to glue the MCPCB on the host. solid thermal glue. with fast heat transmitting.
Glad I ordered before you decided to use glue.
Can you explain the change for us modders? Does the bezel alone apply enough pressure for a good heat path and you are just doing this to be safe or is this required to keep pressure on MCPCB?
wait to see 50.2 3v version.
