Yes, I got the same notice. I am guessing that our FW1As will be going through customs in LA, and then handed over to the USPS for delivery. Fremont was the first stop in the US last week, but it is not a point of entry for customs.
Okay, so the number I was trying to find out was apparently 22.5.
22.5 cd/lm in the XP-L HI version of the FW1A. Plus or minus a pretty large error margin due to my questionable measurement tools.
That’s about two thirds of the Emisar D1, which gets 33 cd/lm. And it’s about 6 times as throwy as the FW3A, which only gets like 4 cd/lm (I measured 3.8 cd/lm on a XP-L HI version with 10511 optic).
And if that’s anywhere near accurate, it means the FW1A should get about 27 to 29 kcd at turbo, for about 330 to 340m of throw.
So it’s less throwy than the official specs claim, but still more throwy than I was hoping. I’m debating whether to add some DC-Fix on the lens to tone it down a bit, since I was hoping it’d be 10 to 15 cd/lm. Will have to try it outdoors at night to check if it’s too throwy or not.
Anyway, initial impressions of the FW1A are good. It does a lot of things right.
If you mean just above, those figures are for the 1A, and I was trying to remember how it would compare to the 3A. I have to leave for work, so no time to search right now.
The numbers are pretty approximate. I measured 3.8 cd/lm at the 1x7135 level on a FW3A with XP-L HI 3D. However, maukka measured 4.46 cd/lm (12500 cd / 2800 lm). And maukka’s numbers are probably much more accurate.
In any case, the FW3A gets about 4-ish cd/lm with XP-L HI emitters… and FW1A gets about 22-ish cd/lm.
Using the same equipment, I measured the FW1A at about 5.95X more throwy, so it goes a lot farther at the same power levels. During normal use, this makes a huge difference. In particular, it can really increase the overall runtime, since it only needs a fraction as much power to achieve the same visible brightness.
However, the turbo level makes fewer lumens, so the maximum hotspot intensity is only about ~2.4X as much as the FW3A. And the maximum throw is about ~1.5X as many meters as the FW3A.
TL;DR: FW1A has a much smaller but much brighter hotspot, so it’s way better for seeing into the distance. If used up close though, it’ll require aiming much more carefully since it lights up a smaller area.
The FW1A doesn’t have a list of literally thousands of people waiting to buy it, so I don’t expect there will be a lot of colors to choose from. Probably just grey. That could maybe change eventually, but it’s far less popular than the original FW3A because it’s a spinoff, so the chance of multiple flavors is probably not very high.
It’s probably also worth mentioning that if the grey one sells well, the chance of multiple colors increases. If the grey one doesn’t sell well, there probably won’t be other colors.
It’s a good light though, so I hope it sticks around.
I guess the problem here is that most of us are probably holding out for different colours and finishes and therefore not buying the standard grey one, causing Lumintop to think there’s not enough demand and therefore not produce any other variants!
I’ve gotta say my bare Alminum FW1A (converted from a triple) has really been serving me well as my EDC. I’m still using an S2+ reflector with a sliced 4K SST20. If I had a complaint, it’d be the beam was actually a bit too narrow. If there ever is a HiCRI SST40 or SST70, that’d make it perfect IMO as a do-it-all light.
Anxiously waiting for mine. I am always a thrower person. Fw3a was never attractive to me just because it is multipla emitter light. Fw1a is perfect to me.
I have thought about it and may do so. If I come across - or someone points me towards - a known good tint of the Samsung emitter then I’ll do that. For now, I’m mostly content. I have the stock FW3As if I need more flood.
Another emitter option I’ve been tossing around is a quad e21a with a heavy OP reflector.
