Picture makes it look pretty deep crenelations for what “meat” is left on that bezel. I guess it’s an illusion or there is more material than it seems to work with. Interesting!
Still a little bit left on the bezel. If you look closely to a stock bezel you can see there is two angles,the one closest to the lens is probably 1mm thick. I stopped at the top of that one.
Oh and I found the o-ring, it was on the garage floor.
I swapped the emitters for some LH351D’s (the venerable “dogfarts” at 5000k) and added an “ice blue” AUX board from Lexel. Some hand polishing and a bit of wax to keep it a little more shiny for good measure.
So was playing around with the bezel again, planned to polish it to a mirror shine but didn’t like how it was turning out.
Decided to take a red scotch bright pad to it for more of a brushed/machined finish. Will probably live on my FW3T and it matches better than on the FW3A imo.
The aluminum is a little lighter in color than the titanium in pics but in person it’s almost identical.
Just ordered an FW3C. Does anyone think it’s possible to form a penny into the shape of the tail button? Don’t know if it would deform too much if I could make a steel die and press a penny into the right shape. Thoughts?
Has anyone put XP-G3 s 4K 90 cri in this light yet —- I’m looking to do something different — I have all the stock flavors and then some —- I’m thinking may a variety of 4K emitters SST 4K / 351D 3.5K / XP-G3 4K
I purchased a couple used FW3As —One had a couple nicks/etc — decided to bead blast and polish it—-I had been wanting to build a Triple with a mix of LEDs—I went with a
SST 20 4K / XP-G3 4K / LH351D 3.5K combination —- tint seems to be pretty nice (on wall so far) — I compared it to another FW3A with LH351D 4Ks — seems to be slightly more Rosey and have a slight bit mor throw—won’t know anything till the night comes
