It wouldn’t be blf if we didn’t get side tracked Pics above should be fixed now.
I made the pill. I hope I left enough room for the wires.
excellent pp, a new comp ,pics aren’t working for me
Doh! I checked this page on the wife’s phone to make sure they were showing. Will go back and try again.
working now
Thanks LTP Worked out I hadn’t set the album to ‘share’ yet
Looks good pp. Your skills are coming along in leaps and bounds. I’d say theres heaps of room for wiring.
Nice build so far! I’m glad my post brought some kinda response, but I didn’t expect a rogue build!
Honest, officer! I was only trying to get the real contest to start!
Thanks moose
It wasn’t me officer , David is the mastermind… err… no I mean ‘the’ … I’m a pleb Honest…
Im wondering Pinkpanda what is the superconductor bar made out of?
According to the seller this is NIOBIUM TITANIUM ALLOY. I’m assuming the orange part is copper and not cupronickel.
Wiki says there is a couple different varieties - Superconductor material classes include chemical elements (e.g. mercury or lead), alloys (such as niobium-titanium, germanium-niobium, and niobium nitride), ceramics (YBCO and magnesium diboride), superconducting pnictides (like fluorine-doped LaOFeAs) or organic superconductors (fullerenes and carbon nanotubes; though perhaps these examples should be included among the chemical elements, as they are composed entirely of carbon).
Thanks- i think it will look great and unique when turned down exposing the different alloys.
That’s the plan. I am far from the first person to do this but this material is not nearly as popular as steel damascus, mokume or timascus.
The steel sounds and looks really really expensive.
looking good pp ,how much is that metal worth?,I cried with the $150 I paid for the metal for my light bar.
I feel terrible now I paid more than you for that little piece. I really don’t want to screw this up.
On the bright side, it looks sweet after machining
pp cant say what hi material cost ltp as his better half would kill him.
Whilst that is true, I also don’t like admitting it to myself
I made some holes in the pill in order to use tweezers to screw it in/out. The holes line up with the mosled holes.
Purrday colours
Threaded and test fit
The retaining bezel protrudes a little more than I was planning due to the not being able to machine threads for the pill right the way up to the shelf/step. I should be able to easily rectify this by cutting off 1-2 threads off the pill
I’ve stalled for a bit trying to think about how to proceed from where I’m at with this build.
I bored out the body but didn’t go right through. I tried to stop around where the tail starts.
I then flipped it in the chuck and bored the tail to suit a rubber boot
Cut off the tail section
The inside of the body looks cool Pity it won’t be seen, there will be a sleeve.
The sleeve, to help extend the length a little. Made from a solid bar of ti. The wall thickness is just under 0.5mm and may require a final pass to open the inside a fraction more once it’s fitted to the body.
Ready for threading
Nice work! I need a few more years on the lathe before i would try material like that.
