Steel can be pretty nice, as long as weight isnāt importand and the LEDs inside arenāt turned up too high.
In a FW3A, Iām guessing a steel version would probably regulate down to the regulation floor, and then mostly just stay there. Steel is good at keeping the heat in, so the highest sustainable level is probably just a couple hundred lumens.
maba, I said it on FB, but Iāll say it here, too. Thanks for the pics! Looking forward to this one. Iād really like to see how it compares to the SC64 and S2+.
Iāve been introduced here by stephenk from a post on Light Painting Blog.
As a lightpainter, from what Iāve read, I think FW1A is one of the best flashlight to have in our arsenal. Especially because of AndĆŗril and its new momentary strobe feature.
Could someone tell me if the FW1A has the new July update of AndĆŗril firmware?
I read FW3A/1A drivers arenāt updated yet by Lumintopā¦
Iāve only tried one FW1A, but it has momentary strobes. I think almost all FW3A / FW1A lights are shipping with a version new enough to include that now.
Checking is relatively simpleā¦ go to a strobe mode (āclick, click, holdā from off), then turn the light off, then go to momentary mode (5 clicks from off) and press the button.
Getting out of momentary mode is a bit inconvenient on FW3A/FW1A though, since it requires disconnecting power. And on this light, that means unscrewing the battery tube pretty far. Itās much easier to exit momentary mode on other lights, like the Emisar D4.
The button placement may also be a consideration when choosing a light. Side switch or tail switch may be more convenient, depending on what youāre doing.
Just received this light today and I absolutely love it. Great beam profile with the SST 20. One advantage of throwy reflector lights Iāve noticed is in tail standing to create diffuse light in a room. The candle mode in anduril is much more effective this way than with optics. Perfect for late night reading.
Ok. So thereās no manual momentary mode yet (your July update), but there is momentary stobes. I can easely live with that. Thanks for your help and your reply!
About the button placement: yup youāre absolutely right. Thatās why I rather choose tail switch button flashlight. Because we often attach some sort of light diffuser (e.g. plexiglass) onto the head causing side switch difficult to reach.
Thanks for your quick reply bmengineer. Useful tip.
The momentary mode supports regular (steady) output or anything in the strobe group (party strobe, tactical strobe, bike flasher, candle, lightning).
What it doesnāt have is āmanual memoryā, which makes the regular ramping mode start at the same brightness every time. Instead, it has only āautomatic memoryā, which uses the last-ramped level. Newer versions allow switching between these two. But that probably isnāt relevant for light painting, and doesnāt affect momentary mode.
The proper version of this light with so little thermal mass. Only.. Why only OP reflector ? Why no SMO.. ? Beats me to death.. :| Small emitter and OP reflector, makes no sense to me.
I was very much excited when the Lumintop rep on AE told me about the EDC18 that was based on the FW3A - that made me think that Lumintop does consider options and variations.
I've just replied that I'm not too much interested into triples, or multi emitter lights in small formats due to low thermal mass and that I would take a single emitter variant any time,
even at the expense of a shorter cell fueling it, like an 18500/18350 if size constraints are imperative.
Not too many minutes ago just randomly found and watched a review on YT about the FW3A and somewhere in the review, the 21700 and single emitter variations of the FW3A were mentioned - moment of awe!
Ofc, I went straight to Google and typed in Lumintop FW1A - low and behold.. the unexpected (but hoped for.. ) happened! Hurray!
Only when I've got to any of the shops selling them.. there had to be a shortcoming.. ONLY... OP reflector as a choice!.. :| Not nice, really a bummer as far as I'm concerned.
Hopefully Lumintop will consider having an SMO reflector as an option for the FW1A any time soon tho :)
