hi,surely can buy it in China.
while I am some busy to do it. I will care it.
What is the driver size? I will want to replace driver with something from Lexel (w/ Anduril) most likely. (BLF host version :+1: )
BLF host version would be cool
Very very very cool
+1
I’m sure it could be adjusted if you can solder microscopic resistors in place
Interested in a host too.
hi guys, I am so hard to visit BLF.
18350 /18500 tubes are in production.
the driver is 17mm
It seems that the BLFers are intersting the host in every new Jaxman models release….
if really necessary, and promise have the skills of assemle it I think I can provide host for BLF.
my email: zx.bao@foxmail.com
wait you.
Will email as soon as 18350/500 tubes are available. Please keep us updated, thank you!
ok. I will tell you here.
Now there is a change on the way of fix the MCPCB on E1. we have decide to glue the MCPCB on the host. solid thermal glue. with fast heat transmitting.
Glad I ordered before you decided to use glue.
Can you explain the change for us modders? Does the bezel alone apply enough pressure for a good heat path and you are just doing this to be safe or is this required to keep pressure on MCPCB?
wait to see 50.2 3v version.
You can email Jaxman and build it for your own. I’ve just ordered a host for triple
hi pleas dont worry about the thermal glue on Jaxman flashlight. The glue has a much well w/m.k value than most silicon crease. And in normal temprature, it is solid, but will be soft and easy to split in about 100 centigrade (212℉).
We can heat it and take off.
Whe we select glue solution is for solid and fix the MCPCB, let it will not turn around. But not for the pressure of the bezel is not enough. There is no relation between the glue solution and the pricision of the parts. Otherwise, it will not be good at water and dust proof.
hi surely no problem.
the 3v xhp50.2 LED is a new emitter, Now we have only the coolwhite tint.
we have use it on our new headlight, M1.
hi see this:
hi please dont worry about the thermal glue on Jaxman flashlight. The glue has a much well w/m.k value than most silicon crease. And in normal temprature, it is solid, but will be soft and easy to split in about 100 centigrade (212℉).
We can heat it and take MCPCB off easily.
My order is stuck in a shipping loop in Hebron, KY.
Package status: In transit
