I guess the “return” section of the website is just for show. I submitted one over 2 weeks ago but no contact or further instructions.
No acknowledgement in this thread of the issues either. Can’t say i’m surprised based on past posts but in the future I will refrain from ordering new products and let other people be Kaidomain testers.
It doesn’t even say to send it back much less where to send it. I don’t see an address listed anywhere on your entire site and no one has contacted me so I don’t know why you are thinking I would have shipped this back for more than I paid.
Return #289 and #290
If the products don’t fit together you should remove them and take it up with your mfg. I’m not shipping unsellable product back.
Feel free to correct me if these products are good and let me know how they are supposed to be used.
The hole in the lens is fine. The dome of LED fits as it should. The lens is going to rest on the base of the LED and crush it there. It does not need to go around the whole LED including base/substrate.
Did you try to put your module in a light with the lens and bezel tight?
A previous version of this optic/board combination from KD (I have one) had a thinner 1mm thick MCPCB which was also not good: the holes were either too wide or the optic needed a bit sanded off the legs. I never bothered to find out what exactly was wrong because I never used it, but it clearly did not work off the shelf, something had to be fixed.
I fully agree with you 1stein. BanL, can you please try to source some Osram Ostar Projection Compact LE R Q8WP LEDs? These are very powerful red light LEDs.
