Amazon reviews are… highly variable in their utility at best. One of the more negative reviews made some reasonable technical points (most importantly that the Osram version does not have as much throw as advertised), but another reviewer’s chief complaints are that it gets hot when making 1300 lumens and doesn’t run on disposable AAs.
I like the TK16/SST-20 over its direct competition for its tail e-switch, standard battery (with USB port if that’s your thing), color quality, and throw (unlike the Osram version, the SST-20 has more throw than advertised (around 170m at turn-on). It’s not perfect; I don’t like its clip much, nor the plastic optic being exposed. I’d also prefer… different texturing.
*PS: *Anyway what penalizes Acebeam TK16 torch is the the absence of the battery charger. Needless to say, it is recharged with the phone charger. It isn’t the same because the battery and the power to recharge Acebeam TK16 is different.
Looking at it from a different perspective…. the Kratax looks like it could be an interesting side e-switch mod host. But, several things could come into play like the driver and how the e-switch is mounted and does it have a real led shelf and is it glued up solid. I am not willing to drop 30 bux to find out, would drop maybe 20.
Thank you very much for your advice. Instead with regard to the lack of battery carger on Acebeam TK16, which would you but between it and Olight S1R BATON II?
The Olight S1 series has been around for several years, and the TK16 is new as of this summer. I don’t have accurate sales numbers to say which is more popular.
Building a USB charger into the battery is a fairly common approach, which Olight also used on their S1 Mini. The battery is a standard 16340 Li-ion; you can use any 16340 rated for about 5A current, and you can charge the USB battery in a standard slot charger. I prefer using a dedicated slot charger like the Xtar VC2S rather than charging built into the light or battery.
Some people do prefer Olight’s magnetic charging, but it uses a proprietary cable and a proprietary battery instead of standard ones.
You are right on everything but maybe Olight S1 torch is better than TK16 for travellers because they don’t have to carry with them a battery charger too. I’m making an error?
PS: I don’t understand the precise battery od TK16, maybe is it a normal CR123A? Is it possible to charghe the TK16 battery (IMR16340NP) with a smartphone charger?
Olight sells a charger that is nearly as small as the Baton chargin cable. Very nice for travelling as it charges everything LiIon and NiMH. Comes with a nice pouch.
Hey, maybe I did’t undertsand anything. But isn’t the Olight S1R Baton II charger included in the package? Do you have to buy it separately?
Is it possible to charge Olight S1R Baton II battery with a charger working at 110 / 220volts? What precise charger do I have to buy? I will use the torch when I travel around the world.
Geuzzz,
wonderful news. But what if I wanted to charge the TK16 battery with a charger working at 110 / 220volts? What precise charger please?
Sorry, I edited my last post in the meantime you were writing the reply.
I’m asking what are the 110/220 volts chargers (electricity), as for Olight S1R Baton II as Acebeam TK16? I need the precise models please.
The battery that comes with the TK16 is a 16340 with an added MicroUSB port. It can charge from any USB power supply including smartphone chargers, USB ports on computers, etc…. It can also be charged in a slot charger like the Xtar VC2S, and the TK16 can also use a standard 16340 without a USB port.
The battery that comes with the S1R is a 16340 with an extra negative contact added to the positive end. It can charge with a proprietary USB-A to magnetic connector cable that is included with the light, and also requires a USB power supply like a smartphone charger or PC USB port.
Hmm… I thought they were shipping with USB batteries now.
The Olight UC and Folomov A1 are very compact USB chargers with magnetic contacts that can be used to charge the included battery outside of the light.
Unheard,
if I take the battery out of the torch could I charge it with a charger by elctricity 110/220?
I’m 2 days waiting to understand well but unfortunately I still don’t understand. Maybe it’s because of my bad English, I don’t know it. I ask the question again hoping someone can answer me exhaustively.
Repeat: I will use the torch in my trips and I don’t always have a computer or a smartphone but only electricity. I’d like to know if there is a specific wall charger that works with electricity to be able to charge the batteries. I’d like to buy one of the two torches just to be able to recharge the battery in the simplest way possible.
Can anyone point me out some precise model of charger working with electricity?
THANKS
Maybe now I understand better. In other words: I always have to use the USB cable and I have to plug it in the smatphone charger. It’s right? Thanks again to clear my ideas.
EDIT: It is so difficult to buy a mini torch. If you were me, which would you buy between Acebeam TK16 and Olight S1R BATON II?
I would chose the emisar D4 Just joking I would go for the acebeam tk16 sst-20 hi cri.
But you have to make your own decision now. Single emitter VS triple. Side switch VS tail switch. Led color temp and cri. Build in charger or not. Choose your destiny.
Every Acebeam TK16 use sst-20 hi cri battery? Is it easy to find it and to buy it?
Triple emitter gives a larger beam too?
I like a lot the Olight S1R BATON II battery charging system. In fact it is not necessary to remove the battery from the torch. Unfortunately with the Acebeam TK16 it is necessary to remove it from the torch. It’s not a trivial matter.
Thanks again one.
