Possible confusion. This thread is about the D4S, but the question appears to relate to the smaller D4 (no S). The SS bezel for the D4S is the same for the v2 as previously offered for the v1. It can be purchased separately and retro-fitted. I have done just that.
The SS bezel for the D4 (no S) has only been available since the D4v2 replaced the v1. Hank said it is unlikely to fit a D4v1. Apparently it will fit only a few of the very late D4v1 specimens. It does not fit my D4v1 from the middle of the production run.
Anyone order the D4Sv2 with the LittoKala 5000mAh 26650 cell? I did, and then saw where some LittoKala cells are fakes. Is the one from intl-outdoor.com legit? How would I know?
I am relatively new to flashlights. If you were to get one, what LED setup would you get? Traditionally I like cool white – neutral and would love suggestions since I don’t know the specs of these leds yet.
If you want sheer power, go for the XP-L HD 1A (cool white) (or 3D - neutral white, will appear slightly dimmer to the eye but this is the one I have, the output is still nuts)
If you want warm white and accurate colour rendition at the expense of output, go for the SST-20 3000K (the 4000K is too green, IMO)
Mine came in today. It was shipped 9/30. Total of 11 days. Must be a new all time record.
That being said, THIS THING IS A BEAST!!!
It makes my D4V2 look dim by comparison, and this is in daylight.
A little big for EDC (OK, a LOT big for EDC) but what an awesome light!
The aux LED’s seem to be about the same brightness as the D4V2. I think there are dim and bright settings, but I did not get into that.,
I got the black one, and I have to tell you - the pictures do not do it justice, It is quite attractive in person. I usually go for the E07 style of light, but this one looks good in person. May have to get another one, lets see how it looks after dark.
Took it outside to compare to some other lights in the dark:
Way brighter than the E07
WAY brighter than the D4V2
The closest one cell light I have is the Astrolux EC01. Close but NO CIGAR.
Compared to the Thorfire S70S upgraded with an XHP 70 6500K, darn close!
The amazing this about this light is the beam is very wide and bright, giving it both great flood AND great throw.
I am just blown away.
