Exactly, but lower is not always better, try to find the ‘sweet spot’
On the other hand, artifacts are the effect of bad centering.
Probably you have an xml and xpl sized gasket. Not the 3030 gasket which is required for the Osram.
Well It looks like i’ve just figured out how much is to much… i do have a spare at least don’t suppose you have a link to the 3030?
Edit: #Attempt2#
Hey thats pretty dam good now, makes my eyes hurt when i look at the spot on the wall and there are no artifacts THANKYOU!! :sunglasses:
Does anyone have any figures for KCD using an L2 host and a somewhat over driven White flat?
So the Jax Z1 finally arrived today, after i dont know how long (seems like an eternity waiting for a flashlight)
Obviously i stripped it immediately to my horror there was a nasty surprise that i didn’t bank on, they Glue’d the star PCB in with copious amounts of white indestructible epoxy Jaxman you SUCK!
Thank god have a lathe and can turn this mess out but anyone buying one be warned
well for an Extra 5$ jax will supply you a bare pill with it…(wish id known that when i ordered) Either way its done now White flat & 14x 7135… fitted Its ok but it still cant rival the crelant
Beam size is the tiniest smidgen tighter than a nightmaster nm400 but the lens is way better quality
I’ll give it a go but ive not had much luck with my camera im not sure what settings you guys use to get those great pictures but if anyone’s got any advice on that it will be gratefully received
I use my phone (a Sony, gives good pictures). I use a combination of manual and automatic settings (fiddle with them) and try to make the picture as close to what I see with my eyes as possible, sometimes I need to adjust the brightness afterwards to get it right.
Many people post beamshots that exaggerate reality unfortunately, or use different brightness settings (often auto) for different flashlights that they compare.
One other tip: do not position the camera right next to the flashlight or it will record an impressive-looking but useless blue ray of light that obscures the distant illumination that shows the actual quality of the flashlight. I use at least a meter distance to the side of the flashlight.
A quick comparison Z1 7g5cs L2 & 1 Zillion candela Lumen Ebay HID (the Chinese seller says)
It’s a little misleading the 7G5 appears larger because the Z1 has far superior AR coating,
the glare makes it look larger and camera is struggling to pic that out
Thinking of putting a 1mm Osram White Flat in my Eagletac M30LC2-C flashlight.
Do you have any idea if this will work well, and how much extra throw I would get from the light?
XP-G2 output is rated at 1280 lumens, so I suspect each LED is getting about 1amp of current.
it was the xm-l2 version from jax store on ally, the beams are focused but my camera cannot capture it properly ill try again with them on a lower brightness
Unfortunately not, i have transplanted the white flat in a convoy L21A, which now does over 500 kCd @5A
At 1m the hotspot on a white wall is 8,5 ~ 9 cm
I have an L2 & C8+ with the higher power CULNM1.TG and 6a led4power drivers… Sure they are Bright but both of my aspheric setups eat them for breakfast using the same emitter/driver combo
Im pretty sure neither are 500kcd , as i recall Djozz & others only got beyond 500kcd using wavien collar’s
