It’s clear that you need a strobe mode you can quickly and reliably access regardless of what mode you’re in when the dogs attack.
Years ago I had this same dog problem with an intimidating standard poodle (The standards are BIG!) who bit me when I was on my motorcycle. I needed to go by his house several times a week so I decided to use a new pepper spray I recently bought, one of the first commercially available pepper sprays in the US, a product called “Repel”. So, next day I turned onto Fido’s block, he saw me and started running til he got close and I gave him a short spray in the face. He jumped up and spun around while I gunned the engine out of there. The next day…same routine, but this time when he saw me coming he ran! I figured the eye injury was temporary since I tested it on a dumb macho neighbor who volunteered.
If all else fails, perhaps you might consider pepper spray as an alternative. Good luck.
I just noticed that the most recent versions of Andruil for most lights seem to be dated 9-28, but the latest for the D4SV2 is from 8-28. Does anyone know whether that is the same version?
Sorry for the dumb. I haven’t used my light (D4S v1) in quite a while. When I went to use it yesterday, it wouldn’t turn off. It’s stuck on. The only way to get it to turn off is to unscrew the tail cap. Pressing and holding the button or clicking it is doing nothing. Nothing changes (brightness stays the same). Is there some way to reset this light? I don’t know what I did to get it stuck on.
On this thread we’ve talked mainly about the sophisticated inner workings of the D4S (thank you TK!), but now I’d like to mention something about the ergonomics of this beautifully designed light, specifically the button, of which there are at least three important advantages.
1) The “hump” which provides instant tactile identification of the button’s location, something that is lacking and often a problem in many small lights with side buttons.
2) The recessed button which significantly guards against accidental activation. (I belt-carry the light in a small perfectly fitting pouch, much smaller and more convenient than the Bianchi 7307)
3) The anti-roll function of the “hump”, very important if you put the light, body-down, on any surface that is even slightly slanted.
These seemingly minor features add greatly to the comfort and convenience of using the D4S. Actually, point one is crucial in a situation where instant activation is required.
What pouch are you using and where did you get it? I’ve been looking for a better way to carry mine and would love any info you can give me.
I agree with you about the ergonomics of the D4S. I wish its features were available in a smaller form factor, because it is a lot to carry, but the upside is the way it fits the hand. The grip, the button, and the user interface all come together in an amazing way with this light.
I used the holster/pouch that came with this light, the Thrunite TC20, which was my favorite before the D4S came out. Its output was similar and it was and is an excellent light, but relatively primitive compared to the D4S. I think that the pouch still comes with the TC20, but $90.00 is an awful lot to spend on a pouch, and I saw no option to buy the pouch separately, so I briefly looked around Google and saw a few things but didn’t follow them up. Of course there’s always that Bianchi 7307 which, while not ideal is perfectly acceptable.
It sounds like there may be something physically wrong, but it’s hard to say what exactly. If you loosen the tailcap to cut power, then tighten it again, what happens?
FYI I’m using the Maxpedition single sheath pouch for my D4S. It’s a fairly snug fit with the elastic band around the middle, but the elastic can be stretched or even cut off if desired.
When I loosen the tail cap and cut power, the light goes off. When I tighten it back up, the light comes on and stays on until I loosen the tail cap again (because I can’t get it to turn off any other way).
Okay, sounds like there’s definitely a short or a dead chip in the head of the light, then. It could be the 7135 chip, the FET chip, or some sort of other contact between LED- and ground. In any of those cases though, hardware repairs or replacements would be needed to get it working again.
If you have a way to measure the brightness, it may be possible to narrow down the possibilities… like, if it’s running at a steady ~130 lumens, it’s probably a dead 7135 chip. If it’s running at 1000+ lumens, it’s probably the FET or a driver bypass of some sort. But that probably doesn’t matter unless you’re planning to repair it yourself.
NOTE: If you or anyone else gets this pouch: It was bit snug but I widened it to perfection by pushing in an object (small glass bottle) of significantly greater diameter than the D4S, and letting it sit overnight.
