http://www.instrumentsystems.com/
PTFE Integrating Spheres - UV measurement for laboratory and production
Instrument Systems offers complete measurement solutions for UV-A, -B and -C radiation starting from 200 nm. The operation of the well-proven Instrument Systems spectroradiometers, e.g. CAS series, with integrating spheres made from PTFE facilitate high sensitivity measurements of UV radiant flux.
All Instrument Systems UV measurement solutions with PTFE integrating spheres are delivered with a PTB traceable calibration.
Features:
Complete UV measurement solutions
High optical throughput due to the use of highly reflective PTFE material
High sensitivity measurements for UV radiation down to 200 nm
State-of-the-art stray light correction (optional)
Wide selection of optical equipments and accessories
ISP 50-UV
50 mm inner diameter
200 - 2500 nm usable wavelength
Application: production, e.g. wafer probing, chip testing
Measurement port options: window
ISP 100-UV
100 mm inner diameter
Measurement port options: window, dome
ISP 150-UV
150 mm inner diameter
Application: laboratory and production, e.g. single-chip / multi-chip testing
Measurement port options: window, dome, LED adapter plate
SMA connector for auxiliary light source: yes
ISP 250-UV
250 mm inner diameter
Application: laboratory and production, e.g. multi-die / multi-chip testing
OK, who is going to buy first?
- Clemence
