Come to think of it, I would like to see this led in lots of lights of varying sizes, especially if they are built with proper heat transfer/ sinking to all of the body and head.
The problem with the k75 is that there is very little heat transfer from the switch section where the led is mounted to the quite large head if the light. That makes it get hot way too quickly to use for long term searching on turbo.
My plan is to do the same thing to it that I did to a very hot rodded k40 i had- strip the anodizing from the corresponding Male and female threads of the head to pull connection and re- assemble it with lots of high quality thermal paste. It made a huge difference in heat transfer, and therefore quicker cooling, in that light.
Ideally there would be a light that had a one piece head and pill section, with proper fins going all the way to the bezel, tapering in depth as they get closer to the bezel. This NL 40 looks like that sort of construction so if they just scale it up in sizeā¦
Sorry I donāt know what driver Vinh is using. He uses his own vn or vnx drivers. I believe him and Richard from Mountain Electronics produces them. But I opted for the single mode version.
If you look sbt90.2 in this thread and the other(I forgot where), it claim outputing 4000lumen and at the same time, guess the candela? 320kcd or roughly above 300kcd. Isnāt that great if it was trueā¦
It has long thrower and higher lumen, the beam comparison look like it has larger hotspot with greater intensityā¦to put thing simple, it outhrow xhp50.2, sst40 and probaly the larger hotspot in long distance youāve ever seen, Unlike beforeā¦sorry, just my own opinion if you dont mind.
Price $30-40 for sbt90.2 bead. Host would probaly gonna cost another 30. Erm sumarise all I think weāve got rought $60-$80. Wew exPansive stuffā¦
Just a thought, I donāt own but one 26650 light, a Skylumen Delta and itās only responsible for pushing 700 lumens so I wasnāt too familiar with the cell. Thanks for your input!
To me size/ weight matters. Iād rather have a nice thrower/ flood combination light with an emphasis on throw in the palm of my hand than have to carry a large reflector strapped over my shoulder. Those lights that throw 2 or so miles exist but for most people are just a conversation piece. Human eye can hardly gainfully and tangibly make out objects at that distance to make difference. I vote for keeping head as small as possible , but enough to provide impressive throw and dissipate heat.
The one with a large reflector can always be a different version of itā¦
I agree, Iām actually searching for the smallest SBT90 or CFT90 high output thrower I can find. This is the smallest one Iāve found, which is why I am interested in the purchase! At a 53mm head, that is the maximum I would want for jacket carry.
