I hope they go ahead with it whether they redesign the light or not. I wouldn’t mind paying even $80. The performance should be really close to a TN40 v2 which is bigger and costs much more. Also will be the same size as a T27 but with double the output.
We’re not sure if it’s happening yet. They’ll probably be a separate group buy for it if it does happen. BTW can someone make a poll so we can see how much interest there is and show it to Mateminco/Astrolux.
One ordered - would have liked to add a few more - but demand of life keeps it real. Thank you for the code freeme - looking forward (very much!) to receipt of my third real flashlight (and first thrower).
It has been 2 weeks been using FT03 SST40 5700K. I am very happy with the result. The first Astrolux brand I’ve own and first long throw light. This is a must own. Here what I’ve found very interesting feature about this light.
*Battery check and telling you by no. Of flash
*Lock-out manually by loosening the tailcap or electronics lockout
*Standby green switch, it felt like it always remind you to always turn your flashlight in lock out mode.
*Thermal dissipation so far very good no problem in 2min. I think it has to do with thermal mass bcos it has no deep fins on head
Ft03 is not suitable for near/close range. Spot is really intense if you used high mode for close distant. But to add an edge how to properly used Ft03, used headlamp that has large spill area or used another flood flashlight. In my case I used convoy s12 on my oher hand. It will give very comfortable environment when walking. Often, I dont walk when I light on Ft03 and just stand still. Trust me it not intend for walking flashlight.
