Would be great to see the light offered with XP-L HI and SST-40 as well for more options in beam profile and tint. A CC driver hitting ~5-6A at max would be perfect for those as well.
That my new lesson today. Tq, appreciated it.
- KCD to distance(meter or km)
- beam profile which is candela/lumen(cd/lm) in this case, cd is really intense while lumen is moderate, thus generating a pencil-look-like beam
Hank said the head is 70mm. Doesn’t 550kcd seem a bit less for that size?
Yes, the metric used to quantify beam shape is “cd/lm”. Here’s a rough guide for what that means.
Assuming XP-L HI in each light (except D18 and D1S V2), Emisar’s products go in this order from most floody to most throwy:
- light bulb: ~0.1 cd/lm
- D4: ~4 cd/lm, ~4300 lm
- D18: ~4 cd/lm, ~14000 lm
- D4S: ~11 cd/lm, ~4500 lm
- D1: ~33 cd/lm, ~1300 lm
- D1S: ~100 cd/lm, ~1300 lm
- D1S V2: ~600 cd/lm?, ~800 lm? (TBD)
- laser: ~10000 cd/lm
For general-purpose “EDC” style use, people mostly like items in the range of roughly 3 to 30 cd/lm, with the D4S’s 11 cd/lm being a very versatile balance. The D4S is a bit large though, so I’d really like something D4-sized or smaller with a single emitter and a ~10 to ~15 cd/lm beam.
I generally use the D4 most because it’s the smallest and has a clip, but the D4S has my favorite beam of the bunch. The D1 is also handy since in 18350 form it’s small enough to forget about in my purse until I need it, and it’s throwy enough for almost anything I ever need.
With D1S and D1S V2, they’re extremely good at what they do, and are unusually compact for the amount of throw they achieve… but it’s rare that I ever need or want that much throw. For people who do need it though, it’ll basically leave almost everything else in the dust, especially for the price.
He also said there are no plans fora SBT90 Gen2 version
550 kcd sounds right. I have a 72mm head with a oslon black and it only does 550kcd.
But I wish he would give us a rear clicky. Side clicky are nice if it was a high output thrower. But for a pencil beam dedicated thrower, a rear switch is better imo.
Rear clickies have two disadvantages: restricted UI choice and internal switch resistance.
That 1st point is obvious.
That 2nd point is having a good enough switch to support high current is quite expensive. Well, compared to an electronic switch anyway.
There’s something less obvious though: standardization for Emisar lights.
By only using e-switches, it makes it easier for them in terms of making stuff, and less overall costs.
I’m sure there will be a Skylumen version with the SBT90.2
If we look at LED price comparison e.g, sst40.sst20, nichia, xhp35, xhp50.2, xhp70.2, osram WF, XPL…vs the SBT90.2
When it come to about, making profit…everything must be lower price as possible as cheaper as it is!
Well he can just price it higher. I’ll happily pay even $85 for it. The performance of that thing is crazy…slightly more throw than an XHP35 HI with over double the output.
So you want a FW1A GT?
Needs a fixed aspheric lens option! How cool would that be
For a light like this, regulated at ~5A or ~6A, the switch resistance is a much smaller factor than it would be in something like a D4 or D18. It may still be difficult to do well, but it’d be a lot easier than with really high-powered lights.
As far as UI goes, I added tail-clicky support two years ago. Most UI functions are on a side e-switch, and the tail provides momentary activation at the last-ramped level. It works fine, from what I’ve heard, and does exactly what people usually want the tail switch to do in a thrower.
Fixed aspheric with RLT/wavien collar. 1.5MCD. That would be sweet! I wonder if someone is going to do that mod.
Indeed it does! I flashed Andúril onto my modded EagleEye X6R as soon as you added dual-switch support.
It’s still my favorite pocketable thrower because of the dual switches and how Andúril works with them. :+1:
I would love a tail switch on my D1S but haven’t found a tailcap with matching threads.
TK, please let Hank know how well Andúril works with two switches.
Is there anyone can translate 550kcd equal to distance in meters or km…?
Awesome news. I always look osram led beam in youtube. Beam look very2 intense…
I am sitting on a modded GT mini by Vin.
600 lumen or something, 300 kcd… the throw is most impressive for a light this size.
I guess I am getting this new light, or maybe see if Vin can up it to 600-650 kcd…
truly wonderful times
SBT90G2 is an expensive led, so it’s understandable he won’t make it an option
and more over, using that LED only make it brighter, not thrower, which is not the target of emisar d1s
I don’t see why the SBT90G2 is hyped that much, just because it’s a new LED ?
Everything is a matter of finding the right combination of host, driver and emitter, just like Hank does with this updated D1sV2 which should be really good according all specifications.
begs a 21700 body
begs a 21700 body
Buy this one and transplant the internals into a Convoy L21A host, which has a 10 mm larger reflector and a 21700 tube.
Edit, my bad :person_facepalming:
I thought i was posting in the nightwatch NI40 thread
