Of all the things I don’t need but suddenly can’t live without…
Vlog 1 – Trip to China and Tube-Talk
veröffentlicht am 7. October 2019 in flashlights von m4d m4x
Hello my dear friends!
if you have subscribed make sure you get the notifications when i post updates or go live!
https://www.youtube.com/embed/KHnGhferHqwmy channels:
my facebook: https://www.facebook.com/m4dm4xdeals
my Youtube: https://www.youtube.com/user/sepp4646
Here is a new deal for you:
(follow my link to the shop for detailed information)
WildTrail BLF D80v2
SST40/XPL-HI 2000LM
USB Rechargeable LED Flashlight
my Code: M6575 your price: $26.99
Specification:
Name | LED Flashlight |
Brand | WildTrail |
Model | BLF D80v2 |
Mode | High-Medium-Low |
Lamp Bead | SST-40 N4 DD 4.700-5.000K, XPL-HI V2 3B 5.000–5.200K. |
Maximum Output | SST-40 version:2000lm@7.5A, XP-L HI version:1500lm@5.5A. |
Driver | FET+5+1 with temperature control (see calibration in the UI chart), Reverse Polarity Protection, Low Voltage Protection(2.7V). |
Dimension | Length:132mm Head Diameter:41mm Tail Diameter:28mm |
Weight | 153grams( without battery ) |
Flashlight Body | Aerospace grade 6063 aluminum alloy either withHA-III hard-anodize or without anodization for a clear look |
Battery Type | 1×18650 rechargeable lithium-ion battery (not included) |
Lens | Double side AR-coated and toughened mineral glass lens |
Switch Type | Tail clicky |
Water Resistace | IPX-7(1meter/3.28ft depth) |
Firmware | BISTRO OTSM User Interface |
Head Spring | Quality Beryllium Copper |
Tail Spring | Quality Phosphor Bronze |
Unfortunately the LUMINTOP EDC18 that was reviewed by me here is different in another point than those mentioned in my review!
THE FINAL BATTERYTUBE IS SHORTER THUS THE EDC18 CANNOT BE OPERATED WITH PROTECTED CELLS!
Banggood.com offered me a groupbuy for the new SPERAS flashlights.
M1 and T1 will arrive soon!
I also reviewed two of them a while ago:
https://www.youtube.com/embed/oCJk-3Lfu2Yplease use my links below to go to the shop for detailed information
SPERAS E1
XP-G3 500LM 170M USB Rechargeable
IPX8 18650 Flashlight
my CODE: MS22 YOUR price: $19.99
SPERAS M1
XPL2-W2 1000 Lumen 119M
USB Rechargeable LED Flashlight Outdoor Waterproof IPX8 EDC 14500 / AA Flashlight
my CODE: MS23 YOUR price: $21.70
SPERAS T1
OSRAM 1200 Lumen 1300M
IPX8 Waterproof 18650 / CR123A Flashlight
my CODE: MS24 YOUR price: $57.69
THE ORIGINAL is available again!
(use my link to get to the shop for additional information)
BLF Q8
4x XP-L HD V6 3D up to 5000LM Multiple Operation LED Flashlight
PROMO SALE until Oct 18th 2019 only US$39.99
Features:
• Compact and lightweight 5000 Lumens flashlight
• Utilizes four XP-L LEDs
• Uses four 18650 batteries for maximum runtime up to 1500hours
• Features advanced temperature regulation (ATR) technology
• Integrated power indicator in side switch indicates remaining battery power
• Flashlight can blink out voltage with 0.1V accuracy
• Intelligent memory function for brightness levels
• Direct access to ultralow and turbo outputs
• High transmittance glass
• Stainless steel bezel ring protects core components from damage
• Constructed from aerospace grade aluminum alloy
• HAIII military grade hard-anodized
• Waterproof in accordance with IPX-8
• Tail stand capability
sitting on the airport towards China
Please accept some time to answer requests :)
Have a safe and pleasant flight. :-)
Any discount codes better than Banggoods Oct 11 - Oct 13 MS18 price of $499?
what means “groupdraw” by the description of the products? thanks
sorry for slow updates
visited Lumintop yesterday
nice things are on the way ;)
Is this usb-c rechargeable? What type of throw does this put out? I’m very interested. Thank you.
Which light?
Weird. I quoted my question underneath a picture of the light in question yet it’s not showing.
My questions are regarding the WildTrail BLF D80v2.
In the description it says “usb recharging” but doesn’t say what type and I didn’t see a charging port in the pictures.
JasonWW: California_Prepper:Is this usb-c rechargeable? What type of throw does this put out? I’m very interested. Thank you.
Which light?
No, the WildTrail BLF D80V2 does not have USB charging. USB charging with external charger maybe?
Some keywords maybe? GT nano, FW21, copper flashlights, ……
California_Prepper: JasonWW: California_Prepper:Is this usb-c rechargeable? What type of throw does this put out? I’m very interested. Thank you.
Which light?
That’s what I figured. thank you for confirming for me.
Short tubes!
Finally!!
I may order a FW3A then.
Are there pictures anywhere of the 18350 tube and stock clip?
Wondering where it lands on the head (of FW3A).
