✌ FREEME- ASTROLUX MF01 Mini 7*SST20 CRI95 26650 ANDÚRIL Flashlight Group Buy - $45.99
There is no test of the Shockli 5500 2019 model, onlt 2017 model or 2018 green model.
Shockli 5250 greens suffer with 20A
I will use the Samsung 40T that handles without problems 25A.
I will have a flashlight with a little less capacity but lighter and more powerful.
It doesn’t matter if the battery can run sustained 20A. It will never do that because the flashlight will heat up and have to step down after a few minutes.
BTW, HKJ did test the Shockli 5500 and it can sustain 20A until full discharge.
This black model that they sell on bangood and other sites?
Could you put graphs at 20A?
I haven’t found any graph of the 2019 model.
Of all the graphics that exist, that is, Shockli IMR26650 5500mAh (Black) 2017, Golisi 4300 protected, samsug 40T, etc. the battery that loses the least voltage in turbo mode is the Samsung 40T which means more lumens in turbo mode, obviously.
It also maintains a higher voltage throughout the entire discharge with 25 , 20 , or less amps.
Yes. That is the cell.
2019 model is same as 2017 model.
Here is 10, 20 and 30 amp. (I already had this picture uploaded)
The 30T is more powerful. I see you have a way to measure lumens and are trying to squeeze out the maximum lumens possible? A 30T would be the best, but most average folks don’t care about the very max lumens, they want high lumens and longer runtime. The 5500mah is a nice cell for this.
Has this MF01 mini got a switch led that can be changed with button clicks?
Interested
The aux LEDs can, but I’m not sure about the switch. It might be on the same circuit or it might be seperate. We might have to wait until someone actually receives one to know for sure.
Hey guys,
What’s a good holster for mf01s Mini?
Thanks
Cloud
Maybe the Convoy C8 holster, the S2+ holster might be too small for the head. There would be also the Astrolux EC01 holster in this size.
I don’t know the exact diameter of the mf01 mini, but the Olight R50 hoster fits all of my current 26650 lights. It’s a rigid design which makes holstering fast and one handed. You can add some foam or a spacer in the bottom for your short lights so it doesnt drop down too far. I think I paid $11 shipped for mine.
The mini is 26650 size. 21700 and 18650 will be too small.
The Convoy C8 holster is pretty flexible. You can fit 26650 flashlights inside, if necessary even a Nightwatch NI40. I don’t own the EC01 holster so I can’t say for sure.
Thank you. I will look into that. I’d like it to be snug in there, not too oversized though
Best option when dealing with BG is to pay with PayPal and hope that Paypal will reverse the charge.
I had a problem with BG earlier this year and this was the route I had to take to get my money back when they simply cancelled my order but refused to refund me. Frankly, if anyone pulls this sort of garbage with me then I’ll think long and hard about dealing with them again. As such, I still haven’t ordered this light simply because it is being sold by BG.
On the other hand, I very recently had a vendor selling on Aliexpress ship me the wrong item (similar but not what I had ordered) and Aliexpress was very quick to dismiss my claim. I was persistent and they issued a refund. I found the initial dismissal to be extremely irritating since I’ve actually had good experiences with Aliexpress and have probably spent thousands of dollars there over the past few years.
Just ordered an ec01 holster. I have others it will fit into but it looks to me the ec01 will be most snug for the mfo1 mini
For how long is this GB code valid?
December 19, 2019
The Gun Grey 4000K that I ordered on Sept 9 shows BACK ORDERED
:frowning:
It’s quite possible that they changed the status to backordered just to prevent people from ordering. You already have your order in so why be bummed out for no reason?
Maybe but it still doesn’t sit well with me (and others) that are left wondering due to status changes with no explanation.
I ordered the same exact one (Grey and 4000K) and wonder if there was an issue with this combination specifically. Anodizing, emitters, ??? It’s not a life or death situation, but it wouldn’t be a bad thing to communicate with customers. I doubt that a company as large as Banggood would reach out individually, but could they relay a message to Freeme?
