Brighter, yes. I’m absolutely agree. In term of flood, it got usable spill. Although it used smooth reflector, the flood is wider and and I think the reason it got bit of throw.
Tint ? I choose 2700k bcos our eyes will feel better and yes, it felt much better than 6500k. But, I have to agree with mocarny, in green forest I thought it will light the green. Well it look not. But fine for me. 2700k become one my fav tint now.
I’m happy you like it, so my WOW about S12 is confirmed.
S12 is short indeed, longer than S2+ and shorter than M3, just in the middle between them. It’s the shortest 21700 light I have…I mean except Imalent DM70 that is disgustingly short as 21700, shorter than S2+ .
I went Nichia too, because of more flood and no tint shift I heard of. Not as much CRI as SST, but very good, a little bit too yellowish, but maybe I’ll use XPL HD another LED in the future… Or maybe this LH351D’s.
What do you use that powerfull UV light for, oweban?
Temperature sensor bothers me in M3, but in S12 flashlight gets really hot before step down, so I assume inside is really hot, I definitely want to keep it.
But this sense resistor in SST40, tell me more Where to solder it?
That’s the sensing resistor - if you run something in parallel with it, it’ll adjust the maximum amps. I’ll list the final current if you add one of the below resistors in parallel:
R010 - 12A
R015 - 10A
R020 - 9A
R025 - 8.4A
R050 - 7.2A
Note that they’re 2010 (5025) resistors - I found it hard to find a mix bag of low resistance in 2010/5025; I got them in 2512 (6332), so the new one overhangs a bit.
Nice review. I don’t usually see people who describe as being allergic to warm light. I like things golden. Green is a funny color. Green seems to pop with cooler light, whereas some of the background colors come out more with warmer light. For instance, birch trees in summer look great under cool white at night. Mixed forest scenery looks more alive with warmer light.
Maybe the problem was this Wizard Pro NW 5700K, so after switching to S12 it was looking more yellowish than it should. Now I think, maybe I should have small AAA size 2700K light, to shine a bit before S12, so the S12 would look very neutral
I see, so stacking, not replacing this existing, thank you
So I’m guess everyone that own s12 has probaly seen how the beam profile look like. Well, it not look round due to reflector designed for 3 leds. It look like a shield shape.
But not just that, if you remove the stainless benzel away, you will yet see a different beam profile or should I say beam edge? you will noted a really nice flower-paddle shape beam. You guy try it on a white wall and I bet you’ll see the different…
It seem to me that, without the benzel look very nice beam edge than with benzel. But, the thing is, benzel is use for cover the lens from stick out…
Just my opinion though, any guess how this happen?
In the top set, 6 I and 0.01 R, gives 0.06v sensing - threw that in the second one along with common resistors (eg. R025 etc, 0.025 I) and it gave off the amps that would be added to 6A by putting that in parallel.
