I bought 3 of these SST20 S2+ with biscotti, just because they were so good VFM; I have only powered one up so far and on a slightly different note to this thread and in the absence of finding the information anywhere else - I went into programming mode to change the mode spacing, which worked without error. Unfortunately I programmed the wrong mode in error, so went back into programming mode and changed the mode again; fortunately I got it right this time as I can no longer get into programming mode to change anything - is this a common failure mode and is there anything that can be done to fix it, or is it a good excuse to try and learn processes for reflashing I if one of my batch has failed this way, are my other 2 likely to go the same way?
I’m not concerned about the apparent failure, as it’s failed stuck in a mode I want and they were dirt cheap anyway and I can use them as triple hosts, I was just curious if it’s recoverable or if I’d need to reflash the MCU/replace driver to restore full functionality.
hello everyone, even though i have boungt the new convoy c8 plus, my old convoy c8 clear suffers from the problem of not be able to change mode. i use the 10 times tap but the only thing that happens is that sometimes it changes the power of the light 100% or something like 30%. Is there somethong i can do to fix this beautiful thrower? i don’t hve acces to programming tools and stuff. Thank you in advance.
Concerning the above Biscotti instructions crib sheet, with mode memory on it reads “enter into next mode”. Seriously? The dreaded next mode memory? Wouldn't it make a lot more sense if it were “enter into current/last used mode”?
I’m trying to decide which flashlight I should buy, so last couple of days I’m reading tons of reviews about two specific flashlights for EDC. One possible pick is Convoy S2+ (with orange peel, for flood). So I’m reading what ppl are saying trying to find out the bad things about flashlights I have in my focus.
So, about this firmware issue… I have a question:
I own a MiniPro TL866A programmer. It came with tons of adapters, so I guess the ‘refleshing’ the ‘new’ firmware (if I pick convoy S2+ and get a bad firmware) would be possible with MiniPro TL866A ?
What kind of package is the IC that holds the firmware? And where to find the latest firmware for ‘refleshing’?
You also mantioned ‘gchart’s Babka’. I guess thats another firmware developer for S2+? Where to find his firmware and is it better they better? (I’m gessing…. at github?)
Another (probably kinda) offtopic question: I want a flashlight with orange peel reflector, but I’ve noticed thats S2+ with orange peel reflector comes with 2 group modes, not like others with ‘smooth reflector’ which comes with 12 group modes. Can I get an S2+ with orange peel and latest (bug free) 12 group modes?
twist3r, Simon the manager from the Convoy store will readily change whatever smooth reflector in your S2+ order to orange peel with ease. He in fact can customize whatever order by ordering first the base flashlight and selecting “other payment methods” (you may need to use the AliExpress application, add to the cart then proceed to see the other payment methods option), then postponing the payment. That way you can message him with whatever custom changes required, and he will later adjust the final price for you to pay. You can also tell him that you're a BLF user, and for it he will make you a discount if you will. :-)
If ordering direct from the official Convoy AliExpress store, you can send a message to Simon (the owner of Convoy), to configure what you need.
So you could ask him to get you a Convoy S2+ with XM-L2 with OP reflector (this is the default anyway), then you could specify Biscotti (12 group modes) with 7135x3 if that’s your preferred configuration.
Unfortunately regarding the “buggy” thing, I’m not very certain what causes that to happen, I have had it happen on some people who asked me to check their flashlights (getting stuck). I have also tried changing the buggy Biscotti driver on a Convoy C8+ to a new (not-yet-buggy) Biscotti driver, as the driver board on Convoy C8+ requires minimal soldering only (I’m very poor at soldering or maybe I don’t have a good soldering iron… — I have not been able to unsolder a 7135x8 driver from a Convoy S2+ head “pill” after several tries, for instance…).
Thanks for your reply Barkuti. Currently I’m gathering so much information that I think its better if I slow down a bit, cause my brain is getting stuck like that biscotti memory mode.
I’m new here, and I’m trying not to bother too many people. Still, I have to ask questions because I’m about to order my first ‘smart’ flashlight. What I would like is a flashligth with flood light and with that kind of light that can ‘flood’ the area in front of me (from my feet up to 3-5m, max 10m away without ugly hotsopt light). If it can ‘throw’ light in the distance, thats a plus. Also I was trying to pick 7135x3 because I wanted the flashlight not to get hot too fast and the battery to last longer, but I wasn’t thinking that 7135x3 would give less lumens compared to 7135x8. Can someone tell me if I’m correct:
If Cree XML2 gives… 1040lm and I pick 7135x8 but use it at 10% mode, that will give…~ 104lm and the flashlight wont get hot too fast and battery will last longer, with light enought to clearly see whats in front of me, without hotspot light (if I pick orange peel)?
When you say you want ‘flood’ without ugly hotspot, and if it can throw in the distance that's a plus, you seem to be asking for a zoom flashlight. Zoom flashlights, with aspheric lens, lose some amount of out the front light when in flood mode (with the lens closest to the emitter), and as you “zoom out” the lens gets farther away from the emitter resulting in a lesser extraction of emitter light but tighter hotspot. But let's avoid being dramatic with the emitter light extraction thing, zoomie flashlights produce excellent and uniform “blankets of light”, being very adaptable (I often every day carry -EDC- one of them). The thread Zooming Model List (2018 Updated) Tell us about your newest zoomie! is a better place to get information on these matters.
A TIR lens will net you a nice blanket of light for close up illumination, with smaller angles being more throwy. I often use an S2+ clone with a 30° TIR lens for close up work (tip: use BLF coupon at FastTech).
Orange peel reflectors give better beam profiles than smooth ones, namely concerning seamless transitions from hotspot to corona and spill (without rings or other possible artifacts even with multi-die emitters). You will still have a hotspot, though.
Last question is a yes, that is a driver swap. If never done you'll need to get skilled on making very flat wire solder joints on emitter MCPCBs, this is because reflectors often sit quite close to them and you don't want to cause electrical shorts (get and use some “kapton” tape just in case).
The reason why I said that if the flashlight ‘can throw in the distance that’s a plus’, is only to make it clear that I want a flood (orange peel reflector type of) flashlight. Ofcorse every flashlirght throw light, but those with smooth reflector can throw further. I mostly need flashlight that will light up the area around me (in front of me) and 3-5 meters ahead, with 10 meters being max that I’m interested in. Everything ahead of that is a ‘plus’ (thats why I said what I said, not because I really need it).
Now, the next information is not important, but I want to explain for what ‘situation’ I would mostly use this kind of flashlight: For ‘flea market’. At the ones in my area, sellers comming before sunrise (which means its still dark or ‘night’), and lots of them already started selling their staff. So I need a flashlight for that kind of situation. To light up the area in front of me (up to 3-5 meters, to 10m being max). Thats what I’m interested in. So I can see what the sellers are offering, and also without being destracted by a hotspot. For that, since I’m an newbie, I would guess 50lm (or 150lm) would be enough to clearly see whats in front of me, and at the same time not waste much battery and not make the flashlight ‘hot’. I guess 40% mode or 30% (of an 7135x3 6T-3B XML2 )would be good for that.
I also read at CPF topic created by Phlogiston (he is a member here as well, but I don’t see that he made the same thread), about Convoy Lights: Option Comparison Tables and Images. I’m not sure that I’m alowed to post links to external sites, so I will not do that but simple google search will find it as a top 1 result. In his topic he posted a tables where he compared some 7135x3 with activated modes like 5–40–100% and he was getting “21 lm —160 lm — 370 lm” for Convoy S2+ Red XML2 T6-3B LED 7135*3 driver. The issue here for me is that I’m a newbie, so I don’t know exactly how many lumens actually looks like in the real life. Is it ~25 enough, maybe 40-50lm ? Or maybe 160lm for what I need? (that flea market ‘thing’).
As for soldering (driver swap), well… I’m not good at soldering yet, though I would like to think that I own an ‘ok’ soldering iron (HAKKO FX-888D). Skill is what I lack.
Since you mantioned ‘kapton tape’ I guess that maybe desoldering requires ‘hot air blower’ instead of solder iron?
Again, thanks for your reply and I apologise for making another offtopic post.
EDIT:
I read more and I’m kinda getting close (at least I want to believe) to what I might decide to ask Simon to make for me for S2+ (if he wants):
firmware: ?
(I need to decide if I want new firmware depending how much lumens in real life at 5-10% and 30-35-40% an 7135x3 Driver can produce. Old firmware had 2 group modes with 5-40-100% (custom mode was possible with 5-30-100), while new firmware gives modes with 1-10-35-100 (group #10). So I have to think/decide about what is the actual difference between 5-10% and 30-35-40% when in comes to light that I would get in front of me or 3-5 meters away)
modes: ?
(modes depend if I will go with old default/custom firware or with new firmware which has 12 mode groups (#10 being the one I’m interested in)
^ those are my thoughts for now. It’s hard to decide but I hope that I’m close to narrow down my final pick.
If you guys have any thoughts/suggestions I’ll be happy to read it. Thanks!
twist3r, I mentioned kapton tape because, when replacing a driver, you will need to desolder the old driver wires from the emitter's MCPCB, leaving the MCPCB pads more or less clean from solder. You will then solder the new driver wires to the MCPCB pads making sure they are remain pretty flat, without bulges. If after this operation you place the reflector over the centering ring/gasket and it touches the solder joints on the pads, you know that needs a fix. If it passes the test, place a couple small pieces of kapton tape over the solder joints to be sure it'll remain short-circuit safe, it's for insulation purposes. Other tapes may also work, but kapton is neat and heat resistant.
If I were you, for a flea market before sunrise, I would select a high CRI emitter of low to moderate temperature (2700K - 4000K). This is just an opinion, of course, but for close up work I prefer light quality. Also, lower emitter tempeatures will respect more your night vision.
If you go with a 3x 7135 driver you'll end up using it in high most of the time. The flashlight won't get hot with such power. You could get an 8x 7135 driver and use it in some medium mode, but it won't be as energy efficient. I don't really like 7135 drivers because of PWM in medium and lower modes, the efficiency advantage of the lower modes gets negated by PWM (this translates into slightly less output); and while most people don't complain PWM can be disturbing to some. For a 7135 driver, I would get one with 4x 7135s and always use it in high; the emitter would get 1.4 A (without PWM), the flashlight wouldn't get too, and you would get a nice deal of out the front light (300 - 500+ lumens depending on emitter and reflector/lens type).
Personally I would go with some (CRI95+ 2700K or 4000K) SST-20 emitter, and one of the newer ∅17mm 4-mode SST-40 linear drivers with temperature control (very nice medium mode at nearly 1.5 A effective, and you have the extra power of a high mode on demand). Simon said he is working on Biscotti for the newer drivers, by the way. The reflector won't be so neat at very close distances, or you may like it. In any case replacing the reflector/lens is easy so grab at least a 25° TIR, I'm sure Simon can ship you some additional lenses with your flashlight for a few extra bucks. Since you don't know which reflector or lens type will fit you best yet, you'll thank this later.
P.S.: I find myself comfortable using my S2+ clone in medium mode (0.9 - 1 A) with a 30° TIR, lighting 3 - 4 meters in front of me.
I’ll be honest. I know you did your best to help me. You gave me lot of examples what would you do. But… now I’m more confused than what I was before.
My biggest issue is that I don’t know how (in real life) certain amount of lumens are good for me (for what I want to use flashlight for, in this case ‘before sunrise flea market’).
I need flashlight to:
-last long
-don’t get hot
-have flood (I think I need ‘flood’ because, in my head, I think ‘flood’ with equally light up the whole ‘area’ in front of one seller, but maybe I’m wrong because it will give less ‘lumens’)
-to not have hotsopt circle ring (if possible)
^ one more explanation why I think it would be good to have a ‘flood’ type of flashlight is, when I come in front of a seller’s staff, if I use ‘thrower’ it will be like snipping some item which would ‘tell’ the seller I might be interested in a specific item (which I don’t want to reveal to him so easily because I want to bargain with him about the price, but not let him know I ‘really’ want it, if you know what I mean) So ‘flood’ light would show me all his items, but not ‘directly’ point to a specific one so fast.
I was at flea market last Sunday, and I did noticed some people with ‘strong’ lamps. I’m sure some of them bought Convoy or simmilar ‘smart’ flashlight, but I knew about all this much less than now, and even if I tried to ask them about ‘what type’ of driver, emitter, or emitter bin their flashlight was using, I guess some of them woudn’t have time to bother with details, some probably wouldn’t even know, and some wont tell). I only noticed (if I remember correctly) that probably 2 out of 3 guys had lamps with that snipping hotspot circle ring. They also were switching off their flashlights so fast, which is what I don’t want to be forced to do. (I guess if they were using 7135*8, they didn’t wanted a lamp to get hor too fast, or to waste battery so fast).
justanotherguy, thanks for your answer!
Yes, I understand what you’re saying, BUT… even if I use 7135*8 at 50%, woudn’t that also (still) force the battery to lose power faster and to get hot faster?
One more thing that I read (post is 3 years old now) is that Convoy S2+ (at the time) didn’t had low voltage cutoff but only low voltage warning. It said that Toykeeper made a new firmware version (probably biscotti) but it was only for Convoy C8 at the time. Is it possible to get such option within the firmware that flashlight comes with? (trying to think about protection as much as I can)
0K. First of all, even if you care to use a warm high CRI emitter like a 3000K CRI80+ XM-L2 or 2700K/4000K CRI95 SST-20, you should get more or less 300+ lumens out the front of the flashlight with a TIR lens if the emitter is driven at 1.4 - 1.5 A (check some emitter reviews like Test of a Luminus SST-20-W 3000K 95CRI led -djozz- or Luminus SST-20-W 4000 K CRI95 color and output test -maukka- if you like). I'm already counting some optic and heat losses, but my figure should be close enough. The TIR lenses will provide you with a nice blanket of light (no hotspot at all), so no one will think you're "sniping" something unless you straight focus at it leaving it in the center of your beam. My close up work flashlight has a 30° TIR, and to my eyes it covers a 60° angle (the figure is a half angle metric). So ask Simon to bundle you at least 2 or 3 lenses (10°, 25° and 45°), or just order a "1pcs per degree" 5-pack (10°, 25°, 45°, 60° and :???: strip lens), that way you'll be able to test by yourself which ones you like better. A lens with a wider angle will spread out the light more, making the beam less intense and you may have to get closer, but at the same time you'll cover a wider area and be able to peek more items stealthily.
As I said above, you can get the SST-40 driver which goes up to 5 A or some Biscotti 8x 7135 driver both of which, in medium mode, will provide you with decent light. The SST-40 driver will give you almost 1.5 A in medium -30%-, while an 8x 7135 in medium mode will be somewhat below depending on the chosen mode group, so it'll be less bright. With 1.5 A at the emitter, a 3000+ mAh cell and a low Vf emitter, you'll at least have 2 hours of non-stop runtime, a little bit more in practice depending on the cell you use. Don't worry with the temperature thing, 1.5 A max means 5 - 6 W of burnt power at the flashlight, it doesn't gets too hot at that power (and anyway, the SST-40 driver has temperature control). I once used my nephew's S2+ with a headband to go jogging (40+ minutes, an after repair test) at night, and it performed wonderfully without getting toasted.
Runtime speaking you can switch modes to save power, and/or take more batteries with you if needed; it's a pretty quick swap.
