They could also use an internal 50W PSU, so only a normal wall cable needed, should, not make it bigger, the Miboxer 4 slot C12 has internal and has 4x1.5A
It’s probably the first USB-powered 8-slot li-ion battery charger that I’ve encountered.
Although as mentioned, the input power (assuming 9v @ 2A = 18-watts max) would be very limiting if charging 8 slots at the same time.
If it’s similar to the Xtar VC4S (when using 9v/2A input power), then the limit could be the same: 1x 3A, 2x 2A, 4x 1A (these are for the VC4S), and then 8x 0.5A (for the VC8).
for comparison:
The Miboxer C8 (8-slot charger, uses external power, DC12v @ 3A = 36-watts) can charge at 4x 1.5A, 8x 0.8A (based on specifications).
In my actual observation for the C8, I notice that when charging between 4 to 8 slots (5, 6 or 7 li-ion batteries), the charging current automatically balances and appears to total to around 6.0 Amps (based on LCD display).
Thus if the Miboxer C8 had been charging 4 slots at 1.5A, adding another battery will automatically modify each slot charging current (assuming “automatic charging current” selection to 5x 1.2A charge current each. If add another battery, that will become 6x 1.0A each. And adding another battery to 7 batteries, becomes 0.85A each. (the “charging current” is based on what’s displayed on the C8’s LCD screen)
Assuming there are no Gotchas with NiMH support or charging protocols in general, I think my buddy will be very interested in this. He needs to charge lots of batteries while on vacation, but they’re not all completely dead and he has all night for the charging to complete.
Hopefully Xtar added some “safety” charging current limit based on battery length? (eg. VC4S can charge a new low-resistance AAA NiMh battery @ 2 Amps charging current, which is not good for the small capacity AAA NiMh battery…). Hopefully the VC8 will limit charging of AAA NiMh to maybe max 1A for AAA NiMh.
Checking HKJ’s reviews and also tested some of them, these chargers use battery length to sort of limit charge current — they differ in battery length threshold to charge at the lower 0.5A current: (quotes are from HKJ’s review)
Xtar/AllMaybe TC2 <= if AllMaybe (an Xtar brand or subsidiary) uses battery length to have lower charge current, I wonder why it’s not done on the higher VC4S model)
“Charge will use 0.5A charge current when battery is below about 52mm”
Xtar MC1 Ant Plus
“Just above 54mm battery length it will switch between 0.5A and 1A charging”
Nitecore F1
“Around 61mm battery length it will switch between 0.5A and 1A charging”
Nitecore SC4
“Charger will change between 0.5A and 2A at around 54mm”
I haven’t checked which other chargers, but pretty sure there are others.
Ordered this charger and received it, but haven’t fully tested yet.
But some first impressions:
USB input:
it uses USB type-C input, is able to use QC2/9v (or regular 5v/2A). I’m testing it using QC2/9v. Comes with a USB-A to USB-C cable.
(it has the same “issue” as the LT1 lantern charging, if connect via USB-C to USB-C cable to a true USB-C power adapter, then the charger doesn’t power up)
battery length supported:
-protected 21700 battery fit the slot (I have the Rofis 5000mAh protected 21700 from Rofis MR30 and Wuben 4800mAh protected 21700 from Wuben TO50R) and they fit in the VC8 slots (but is about an exact fit with little extra room). My guess is probably 76mm length.
charger design:
the VC8 is basically 2 chargers in 1 physical body:
channels/slots 1-4 is like “charger #1”
channels/slots 5-8 is like “charger #2”
each charger is controlled by 2 buttons (controlled separately) and also has its own LCD display ; the functions also operate independently
charger #1 (ie. slots 1-4) = has charging / grading / storage mode (all slots in ‘charger #1’ will be doing the same mode, eg all will be in ‘grading’ or ‘storage’ mode only if set to that mode)
charger #2 (ie. slots 5-8) = has charging function only
charger #1 has its own LCD display while charger #2 has its own display (controlled separately)
-it now has manual charge current selection (2A/1A/0.5A/0.25A). The 2 outermost slots (slot #1 & #8) can be set to 3A.
(each charger can be manually set to the same charging current: eg. all slots in charger #1 can be manually set to the same charging current, while all slots in charger # 2 can be manually set to a different charging current)
(I haven’t done much testing on max charge current, but the manual indicates at most (using QC2-9v): 1x 3A, 2x 2A, 4x 1A, 8x 0.5A;
thus if insert 3 batteries, than can only charge at max 1A; and charging 5 or more batteries, then at most 0.5A charge current).
“charger #1” (slots 1-4) functions:
a) normal charging mode: can switch each display to show ‘charged capacity’ / ‘real-time charging current’ / battery IR ;
battery voltage is always shown
charging current can be manually selected (3A/2A/1A/0.5A/0.25A) and applies to all slots in “charger #1” or in “charger #2”
b) ‘grading’ mode: the manual says it discharges at 0.3A ; the display shows discharged to a low of 2.60v (LCD briefly displays 2.59v before bouncing back to a higher voltage after a discharge) ; the charging current can be manually adjusted while in ‘grading’ mode (I haven’t verified if it does follow the manually selected charging current though)
c) in ‘storage’ mode, nothing can be changed (except to change to the other function modes) ; only displays the battery voltage
“charger #2” (slots 5-8) only has the (a) normal charging function.
LCD display backlight will automatically dim after several seconds, but can be manually turned off separately for charger #1 LCD display and charger #2 LCD display.
- doesn’t appear to have “thermal” sensor
doesn’t have a “time” display (charging time might have been useful in knowing if it’s taking too long to charge a high-resistance old battery)
-I haven’t checked how good it is at automatically choosing the charging current, and whether it will try to charge small capacity batteries (eg. AAA) at too high charge current… but at least has manual charge current override (but cannot select individually per slot — instead it applies to all slots 1-4 or all slots 5-8)
Some more info about the VC8:
- I tried testing max charge current based on some battery length:
- for AAA/10440 and 16340/18350 batteries : max charge current will be limited to 500mA
- for AA/14500 (flat-top & button-top); I haven't tested the extra-long button-top protected 14500 yet : max charge current will be limited to 2000mA
- for 18650 & larger batteries, max charge current 3000mA can be selected
(ie. you can manually select a higher charge current, but if it's a shorter battery, the charge current will be limited to the above-mentioned charge current)
this is an improvement over the Xtar VC4S on two points:
a) VC4S doesn't allow manually selecting charging current (charge current can be indirectly limited by using a less power USB power source or placing more batteries in the slots)
b) VC4S is known to charge AAA NiMh batteries at 2000mA with its automatic charging current (non-selectable), while the VC8 limits it to 500mA, and is also manually user-selectable to the lower 250mA charge current if desired
Built-in real-time temperature control protection system makes the battery charging process more stable."
A little short on details like whether it throttles individual bays, but at least a modicum of assurance that charging won't result in sparks followed by a giant wooshing sound.
Other chargers that will fit protected 21700 would be:
Miboxer C4-12 (new 2-button version)
Yonii-Q1 (single-slot)
Xtar SC1 (single-slot)
and of course magnetic chargers like the Olight UC, Folomov A1, etc.
