Fireflies PL47G2 Discussion Thread
The beam is perfect. A bit bigger than the stock optic in a Emisar D4. I ordered mine with 219B.
Side by side with my D4Ti, with 219b. The PL47v2 is a bit brighter. Being firmware or other factors i don’t know. But it def’ has more power.
The first pic is a comparison of a D4S with tint mixed 219C’s. 2x 4000K and 2x 5000K. vs the 219b’s 4500K.
Other pic is the “ice blue” AUX leds compared to the D4S’ cyan AUX. The PL47v2 is bright. The AUX settings are; OFF - FLASHING - ON.
There is no low for some reason. Looking forward to getting a flashing adapter so i can mess with the firmware :slight_smile:
Other than that tiny little firmware thing, and wishing the magnet was a tad stronger. It’s still a 9.5/10 recommendation.
I ordered mine directly from FF a few days after they released it :partying_face:
Received my PL47 G2 with 219b sw45k. First impressions are very good. The switch is muuuch better than on the first models and the ice cool aux lights are neat. The tint is glorious neutral white with rosy tint, which brings out color beautifully. Very happy with the backlighted switch too. Didn’t realize this had a modified Anduril, was a bit surprised that there was no blinks at floor/ceiling/7135. But no important features are missing from what I can see. It even has the manual memory, which was added recently (five clicks from on).
Wow, duv –0,0098 on turbo, that’s monstrous :smiling_imp:
I’d happily take something mildly negative duv instead.
It would be also nice, if FireFlies could source SST-20 from the GDx tint quadrant (slightly below 3500K).
Wow!! So far so good. 9.5 rate? Gosh… I was right about this light, high cri, high power, 21700 capabilities and anduril…it just right for what I’ve looking for!
Maukka also like it…anyway big thank for cri test and now confirm High cri from this light is awesome news.
But why? isn’t that indicator for as a “FLOOR” and “CELLING” of ramping mode. Its not a big deal, IDK…what do you think guys? We still had time since it hasn;t shipped yet and can direct it to Freeme if script can be reverse back to original… :question:
@hasddie293, you are going to absolutely love it.
It’s not a big deal though. Would prefer the original way, but as long as you configure it right, it’s going to matter at all.
High CRI with a very nice balanced floody beam(SST-20 of course).
Superb handling.
Stronk magnet. :slight_smile:
FD2 SST-20s. I got lucky since the first units came with FD2 SST-20s.
Great Anduril UI.
Creamy output
Good thermal handling.
Stupid good waterproofing.
Well, hand-off then… let just assumed all good to go… as I said before it not that big deal. Ok move along.
Another good credit from BlueSwordM, have fun there.
Some standby drain measurements:
PL47-2 AUX off: 0.09mA (6.3years to drain it’s 5000mAh cell)
PL47-2 AUX on: 1.75mA (119days/0.33year to drain it’s 5000mAh cell)
The AUX leds are BRIGHT, but also sucks a lots of juice. As a comparison; the light consumes 3mA on the ramp floor (219b leds).
But i use the AUX leds to indicate the light is “active/not locked out”. I always unscrew the tailcap to lockout my e-switch lights. So the high AUX drain is no biggie :beer:
I like that even with turning the aux leds off, the two switch backlights are still on and like you tested, their drain is negligible.
So I just received mine and put a 30Q in it. I got the sst20 4000k version. Is the 30Q a bit too high current for this version? I have not noticed any issues but can’t see any specific warnings about using high current cells.
Should be fine. 30Q peaks at 20A, settles at about 15A, thats max 5A pr. emitter. The SST-20’s can handle currents above 6A, so no worrys :slight_smile:
The driver will throttle down due to heat, waaay before the emitters takes any damage
Can anyone measure the inside diameter of the Fireflies PL47 gen II tube? What 21700 batteries are you using? I bought 2 Shockli IMR Purple 4550mah, and they are somewhat thicker than normal, 21.5mm or so. Will they serve for the PL47 GEN 2?
Yep, having the same problem with my 26650 Shockli batteries, they want come out my Haikelite SC04…
I don’t have a gen II, but my gen I measures 22.2mm(I assume gen II has still the same batterie tube)
Thanks for your reply. Well, if the tube measures 22.2mm there would be no problem to use my 21700 Shockli. Good news.
By the way, I also have 26650 of Shockli, IMR 5500mah, and they fit without problems in my Haikelite SC01 and SC02.
Next week I hope to receive the PL47 Gen 2 and I will tell if there are problems or not with the 21700 of Shockli.
I just put a Shockli 4550mah 21700 in, and it fits fine. A bit snug but not tight. Also a Liitokala 4000mah 21700 fits too.
Perfect! Thank you very much for the information. I hope my PL47 Gen II arrives soon
I red somewhere that flashing the Gen I was only possible when the aux leds were disconnected.
Is that also with the Gen II?
i already recieve now.
confuse a ramping mode .when i press 1 click. its high level. but i press to level down and press to off.
when i click again. its jump to high level again. not remember last level.
What am I supposed to do?
Looks like it is on manual memory mode.
When light is on, press 5H(4 clicks and hold the 5th).That should solve your problem
its works. thank you sir.
