Modding a Brinyte BR3000 host 3XM-L T6/ 3- 8x7135 drivers and 3- 4/3AF NiMHs - build log IT'S FINISHED!
Updated with more photos of the battery holder mod in the first post
Awesome work , once again .
Making flashlights with a hammer.......wow.
Love it.
Amazing work. This takes flashlight modding to a new level, at least for me.
Dang thats mighty impressive. Ingenius work with the copper sheet. I see that stuff at my local OSH and never would have thought about using it this way.
I had some 4/3AF NiMH cells I harvested from an industrial pack at work, unfortunately they were all no good. Curious what is the power density of 3x 4/3AF in series compared to 3x 18650 in parallel?
thanks and nice job so far
3x18650, depending on which ones and if they are matched, should have more mah than the NiMH. These are supposed to be “Sanyo”, but I’m betting they are not. Not according to the generic green label with no info on them. Listed as 4500mah.
You should see what I can do with a sledge hammer, of course I can’t pick it up any more.
I am probably going to make a new set of contact plates and not bother with the raised area for the + contacts. Since these are flat top batteries, it's not necessary, just flat contacts would be better.
Edit: Actually I should have said "Can't touch this".
Actually, I suspect Chicago has more flashlights than he lets on. Fess up W . . . how many ya got?
Foy
Photos of the paint scheme in the first post now.
Awesome!
Most excellent metal craftsmanship. Thought I was the only 4/3AF user on the forum. Keep up the good work! :-)
That's sweet! I have one coming from Chicago also.
Now I gotta go pimp my DRY...
You never cease to amaze me OL
Amazing.
Didn't think a Dry could be good looking . . .
illbedangedFoy
Waiting on emitters - Again!
I received my orders from CNQG and KD. My three XM-L 1C turned out to be two 1C and the third one is something totally unknown, not even the same star. Not worth going thru the hassle. I have more ordered anyhow, but Again, it's 2-3 weeks out!
Glad I wasn't depending on this light to work soon! What a bunch of s**t........
I'm done bitchin now,
For a few minutes.
I am doing this light with TJ's Master/Slave setup, to retain the lower voltage, so I can use 3 NiMHs. I have put up a few photos of how I have wired these drivers, to fit in the base of the head.
If it's right, then it's at least. a view from a different perspective.
If it's wrong, then at least some of you guys will chime in Before I put it all together and fry three drivers and emitters? Maybe?
tri1
These three drivers would not fit laying flat, in the head. I had to do a little massaging on the edges, to make them fit in a smaller circle, by sanding some flats, where they came together and at the edges, where they touched the inside of the head. Since they all have to be grounded together, I just soldeded the edges, so they would be one solid mass and it was much easier to handle.
tri2
Here's how they look sitting inside the head's driver recess.
tri3
tri4
The wires here are solid 22ga teflon coated wire. I decided on solid, because it was much easier in this application. I could form them and hold them down with masking tape, while I soldered them in place. The closest board is the master and even though it looks like it's soldered to the LED+ pad, it's soldered to the first pin of the 7135 chip. There's just a hairs breadth clearance there and I will flow some Arctic Alumina to cover in between that pad and the wires, to make sure there isn't going to be any contact. In fact, I will cover all the connections with a touch of AA for my peace of mind.
tri5
The RED marks are where I cut the pins to the controllers, on the slave boards. I thank DrJones for clarifying that for me. It's SO much easier to cut those legs, than to remove all that crap off the slave boards.
tri6
Here's the wiring finished. The green wires are the negatives from the LED- pads and will go out to the negative sides of the emitters.
tri7
The Positive (Red) and Negative (Green) on this side of the Master board, go to the battery positive and body ground, via the Brynite contact plate that fits over the driver recess, in the head.
I have to say, that this is the most stressful part of modding, for me. I am not good with a soldering iron on these tiny connections. Mostly due to the problems (steadiness & eyesight), inherent in getting older (for me anyhow). I am using a lighted magnifyer now and for this go round, I held the boards on the table with masking tape, so I could put both arms down flat on the table, to help steady the iron. It worked better and I "think" it will hold as it should. Time will tell.
I feel I need to do whatever I can, to make this work, If I absolutely cannot, then at least I can say I have tried all I know to do. Foolish pride and the (it's a guy thing), does not allow me to let it go, nor to give it to someone else to do it for me. I wasn't taught that way and I'm not about to change now. Right or wrong... I can always go back to bare hosts and just doing the cosmetic stuff. In fact I will be doing some more of them, but not till fall, since it's getting way too warm already. I'm trying to finish up these more complicated mods and get them out of the way, before the summer heat hits full on.
Anyhow..... I'm off my soapbox and back to work.
Carry On.
I got my order from CNQG (actually from fancylights.com) and now I have the U2 emitters to finish this build.
Unfortunatley my computer crashed on Sunday and we lost internet connection today! Suddenlink says it will be a week before they can come out, so no internet till the week-end (maybe). Hopefully my puter will be back in line by then as well. I can only post here, at work, so no photos. I will have to update some time next week, but it will be done and hopefully, up for sale by then.
The mods look great O-L.
For all of the complaining about the soldering, it looks pretty darn good...
What fun is there in life, if I can’t complain? Tongue Out
